August FS Thread
Old Aug 14, 2013 | 08:03 AM
  #51
YSOFCR-VA's Avatar
Default Re: August FS Thread
2 brand new 044 Bosch fuel pumps with fitting and bracket $480 shipped
Aeromotive A1000 eliminator barely used $250
Shroud parachute new never used $225
Aeromotive A1000 fuel pressure regulator $125
b16/Gsr pro drive oil pump gear $100
precision 1200 cc injectors $250
B18b Aebs sleeved 84mm block bore and hone has already been done ready for assembly brand new $1350 plus shipping
Sorry im having problems uploading the other pictures for more picture please call or text 540 607 0093
Old Aug 14, 2013 | 12:52 PM
  #52
b16hybridsol's Avatar
Sorry for the cell quality pics
H22a1 short block, freshly built 0 miles
-Golden eagle sleeves, step decked and o-ringed
-88mm CP pistons, 9:1, calico coated skirts, thermal coated tops
-Crower pro billet I-beams
-Calico coated ACL bearings (mains and rods)
-ARP main studs
-Kazien balance shaft removal kit
Machine work was done by Champion Performance out of Centerline, MI and setup for around 700-800hp. Prefer pickup unless you want to arrange shipping. Need $2500 out of it, I’ve got much more than that into it.
H22a1 head, about 1k miles (comes with cam caps and a hondata gasket)
-head and IM fully ported and machined by Dart in Troy, MI
-Full Supertech valve train, 0.5mm over nitrate coated int. and exh. Valves
Need $1200 out of these, and again I’ve got much more than that into them
Old Aug 14, 2013 | 08:36 PM
  #53
bcperformance's Avatar
For sale t1 dual fuel pump hanger.. w 2 to 1 fitting.. brand new I decided to use one pump.. 200 shipped.. text me for pics sorry bad at this computer thing.. 775 219 3176 Chris thanks
Old Aug 16, 2013 | 04:17 AM
  #54
turbotypeR@SPEC's Avatar
25 Year Member
Rolling shell-$10k non neg price! Don't ask! This is a crackhead price! 25.5 cert chassis, Progress custom coil over setup, custom front, shaved bay, custom flat paint by Goolsby customs, fiberglass tailgate, CCC spoiler, carbon hood, weld ...rear skinny's, Exospeed 15x9 fronts with 26x9 toyo's, Kirky seat, stroud window net, custom staging brake, stroud parachute, sumped tank, Mfactory LCA, and I don't know what else I'm forgetting. I also have enough carbon wrap to do the hood, tailgate, and rear diffusers. I will do that before it leaves here.
Old Aug 16, 2013 | 04:29 AM
  #55
25 Year Member
Chase Bays b series mil spec harness-$1000
Custom torsion bar setup from EG hatch-$500
Chase Bays brake booster delete-$175
Driveshaft Shop Pro Level axles w/spool-$2250
Weldon fuel filters I think they are 10 & 50 micron-$100
AEM fuel rail with sample valve and SX regulator-$250
Racepak Logger dash-$1200
Weldon 2025 fuel pump with fresh rebuild from Weldon-$600
MSD Digital 7 plus 75314 ignition box-$750
Old Aug 16, 2013 | 07:01 PM
  #56
Boosteddb8's Avatar
An original Venom F22a/H23a intake manifold $300.
Old Aug 17, 2013 | 11:03 AM
  #57
tscook3's Avatar
Synapse turbo v-band outlet top mount manifold for b-series. For use with precision vband inlet turbos. In great, used shape. Awesome manifold. $750 obo.
Link to manifold listing on site:
http://www.synapseturbo.com/mm5/merc...kits_manifolds
Pictures:
Old Aug 17, 2013 | 11:12 AM
  #58
DKPR87's Avatar
FS: H23A Log Manifold
$60 Shipped OBO
Helping a friend clear some room in his garage.
Old Aug 18, 2013 | 11:49 AM
  #59
mugen22's Avatar
For Sale: H22 Moroso Oil Pan and Pickup - $300
H22 Moroso street and drag race oil pan and pickup. Used for less than one season! Bought this pan for road racing and it definitely is not designed for it. Unfortunately, the vagueness on Moroso’s website is my loss and your gain! The pan is in perfect condition and everything is there including the mounting hardware. The only thing you will need is a gasket for the oil pickup and re-seal the oil return bungs. You will get:
- Moroso Oil Pan #20912
- Moroso Oil Pickup #24012
- Modified H22a4 engine stiffener
- Mounting hardware (you need to get a pickup gasket)
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
Old Aug 19, 2013 | 12:31 PM
  #60
HTurbo845's Avatar
AEM EMS v1 1040 box- $500 or trade for s300
box is still in car and is in perfect working condition
email- thompsonader@gmail.com
cell- 845 494 5533
Old Aug 19, 2013 | 07:18 PM
  #61
JDM JEFFREY's Avatar
Qsd k2h 100.00+ shipping
Skunk 2 k2h 100.00+ shipping
Old Aug 20, 2013 | 01:32 PM
  #62
PRO1's Avatar
AEM V2 6040 OBD1 $800
704 604 3526
Old Aug 20, 2013 | 05:18 PM
  #63
got-vtec?'s Avatar
Quaife lsd for gsr. 10 passes. Doesn't come with ring gear. $600
Precision low impedance 1200cc injectors $250. only seen track time.
Gsr transmission, works fine. $400
Gsr gear stack 300, works fine. $300
B16 transmission, works fine. $400
Walbro 400- $100
Old Aug 21, 2013 | 08:36 AM
  #64
FaceTuned's Avatar
contact: Tony@facetuned.com
Phone:253-238-070zero
paypal: same as above ( verified as well)
BUYER WILL COVER PAYPAL FEE'S
PRICE:$2800 SHIPPED / NO TRADES / NO LOWBALLERS PLEASE / I AM
FLEXIBLE ON THE PRICE.
Here it is, im selling off my turbo kit from my personal race car.
It consist of...
  • FTT T4 DIVIDED FRONT MOUNT / TWIN 38MM MVS
  • S372R T4 TURBO WITH 1.00 HOT SIDE MINIMAL SHAFT PLAY SPINS
  • FREELY AND MAKES GREAT BOOST.
  • 4" SIDE EXIT DOWN PIPE
  • TWO BLACK 38MM TIAL MVS WASTEGATES WITH 14PSI SPRINGS
  • 2 DUMP TUBES
  • V-BAND CLAMP TO INTERCOOLER
  • 3" CHARGE PIPE
  • TIAL Q 50MM BOV
  • T-BOLT CLAMPS
  • OIL FEED LINE(-4)
  • OIL RETURN LINE(-10)
  • MANIFOLD BRACE TO BLOCK
  • MAC VALVE WITH ALL PUSH LOCK LINES INCLUDED.
I BUILT THIS KIT WITH INTENTIONS OF STREET USE IT TUCKS PERFECTLY BEHIND AN 98-01 INTEGRA FRONT END.
MIGHT FIT CIVIC / EK CIVIC AS WELL NOT 100% ON THAT.
I MADE JUST ABOVE 800WHP AROUND 30-35 PSI WITH THIS SETUP.
ABSOLUTELY NO CREEP
IF ANY WANTED TO SWAP OUT THE TURBO WITH A SMALLER WHEEL UNIT YOU COULD DO THAT AND USE IT ON THE STREET.
ON FOR THE PICS.
ANY QUESTION PLEASE CALL OR PM ME.
PRICE: = $1000 + Shipping
[/I]
I got a full set of slicks / skinny's For sale
[/B]
Bogart 13x8 rims with i believe is a 4.5 or 5" back spacing they fit my integra,
the rims are already drilled and screwed(bead locked) and have some M&H
Race masters mounted front and back.
front need to be changed there's just to many passes on them.
Pm / e-mail or call me to purchase.
Regards,
Tony
Last edited by crazes; Sep 3, 2013 at 10:57 AM. Reason: only one post allowed in for sale section
Old Aug 21, 2013 | 03:42 PM
  #65
tylerart's Avatar
3 piece fiberglass front end never been driven with it on $600
b series msd ignition system $150
hondata s200 $100
golden eagle b series fuel rail with liquid pressure gauge $125
gsp gt45r twin scroll turbo with 4 inch up pipe $500
H&H mini outlaw manifold with 65mm tial waste gate and wastegate dump tube $1200
rc 1200 injectors b series $200
If you have any questions or anything the fastest way to reach me is to text me 661-733-4630.
Old Aug 21, 2013 | 10:44 PM
  #66
therunnerz's Avatar
all parts new or in working order text please no pm thanks 214-576-6367
Edelbrock ported and custom extended manifold with two rails included $400
Type r oem cams $200
Mezeire electric water pump and mezeire idler $150
Dry sump oil pump with lines and brackets missing oil pan $300
Tilton carbon carbon clutch missing disc but all there except that $600
J/e 81mm brand new pistons $250 (2 sets)
h23 arp bolts new $80
d16 pistons Je brand new $250
steering wheel $100
S2000 fullrace manifold with downpipe and dumptubes $900
two 44mm wastegates tial $400
s2000 rywire harness with firewall plug $500
s2000 t1 catch can with lines $250
koyo radiator $300 with shroud and fan $250
s2000 block and intake stock $300 legit vin
Old Aug 22, 2013 | 11:03 AM
  #67
Will_H's Avatar
Mint Aeromotive A1000 fuel pump with a mfg date of 12/07. The pump has only had c16 run through it. Works perfect, not a single issue. I made a little over 800hp with this pump. Comes with a Aeromotive 100 micron filter(silver) and Aeromotive 10 micron filter(red) Both filters elements are 8 months old. 40 total passes on pump. $425 for everything pictured!
Old Aug 22, 2013 | 12:07 PM
  #68
h-duced's Avatar
Up for grabs is a Brand new Koyo radiator with -16 fittings welded on already. Comes with the -16 AN fittings, enough hose to plumb, and two extra -16 bungs to weld on. Shoot me a text at 262-914-4698 or pm me. Local pickup is fine OR I can ship within the states. Buyer will pay for shipping and payment will be by paypal unless its a local pickup. I got over $400.00 into this radiator. The lines, fittins, and bungs alone was 200 bucks and then the money I paid to have them welded on was another 50 bucks. ASKING $300.00 FIRM. EVERYTHING IS BRAND NEW.
The reason why I am selling this setup is because I went H2B and will not work with my setup.
Old Aug 24, 2013 | 04:43 AM
  #69
MoiMotorsports's Avatar
im selling my car 1995 civic ex coupe it use to race in Florida i have a Florida title to it the car as raced its whole life it only has 35k miles on title
i can sell it as turn key i would like to sell the rolling chassis im not in a rush to sell it want to do a rwd car if this dose not sell i will convert it or make it a street car... u can use this car for pro stock like i did in 2011 2012 or a 11.50 index 10 o index u can put a stock gsr in it and it will go 11.50 weigh with a b swap is 1680 it the roll cage mild steel so if u were to change it to chrome molly u can save more weight. i installed the kens kustom straight Axel setup and u can make alot of adj with that where u can change the wheel base so it will 60ft better i has wheeli bars all the windows plexi glass from the company fall (everything in the car there are no short cuts or cheap parts
the price on the car is obo i can take parts off if u don’t want certain things
all u will need is your swap and u can go racing $7,000 i can take off alot stuff where i can just sell u the body i willing to work out a deal even trade for a 99 00 civic si or a fox body mustang
(856) 332-5450 text or call
i will also part the car out so if someone is interested on the car it will be cheaper if some on buys parts off it
kens kustom 4 link with weld racing 5 star wheels with aero space brakes 3,500
nitro 5 gallon fuel cell brand new never used $300
full 10an bradied with fittings line with 6an return with aeremotive fuel filter and regulator
$500
skunk 2 pro upper control arm $200
function forum 2 1 pieces suspension with drag springs $500
nos dry direct port kit $450
edelbrock wet direct port kit $400 still in package
13to1 wiseco gas ported lsv motor with a fully built gsr head ferrea comp plus valves std size springs retainers keepers all matching with electric water pump (can sell with out take $350 off price) motor is assembled with honda bearing has less then 2hours on it
$6000 i can tear it down to show u that its ready to go...
22t water pump electric b18 gsr $300
willwood clutch mater cylinder from kens kustom $80
fluidyne b18 race dampener $300
full hydro b16 trans with quafie gear set with diff and all new honda bearings and synros $4800
some videos
ALEX MOI ALMOST THERE - YouTube
Jake & Alex 7-22-10 - YouTube
Alex Moi Atco pan american nationals 2010 - YouTube
moimotorsports - YouTube
2525 E. Landis Ave., Vineland, NJ 08361
(856) 332-5450 cell or (856) 691-4463 home
moimotorsports@yahoo.com
Old Aug 24, 2013 | 08:52 PM
  #70
Zer0_SpeedWorks's Avatar
For SALE!
Racepak IQ3 EFI CAN module for AEM series2/EMS4
BNEW just took out of the plastic to test.
Im just selling the cable. NO IQ3 DASH
300$ shipped FIRM
Paypal only
PM me!
Old Aug 25, 2013 | 04:13 PM
  #71
DDTECH's Avatar
FS:
Accufab 90MM Mustang Flange Throttle body. Will come with brand NEW TPS and BRAND NEW IAC Block off plate/gasket. TB is BRAND NEW, was mounted up, that's it.. Asking 285 shipped, which is a steal.FIRM.
screen shot
screen shot
image hosting
image upload no ads
Prototype H22 Cams I've designed for a shelf profile. Cams are ment to be a great upgrade for Stock block h22 setups or mildly built h22 setups. Specs are as followed:
.488 valve lift with 266 duration on intake
.475 vlave lift with 260 duration on exhaust - 600 shipped
lightshot free download
screencapture
screenshot captor
Email: Derek@DDTECHCAMS.com
Cell/txt - 225-384 1 Four Four 1
Old Aug 25, 2013 | 05:48 PM
  #72
Blown90hatcH's Avatar
FS: B-Series Mil-Spec harness out of my 2000 Civic race car. All DR-25 Raychem heat shrink and adhesive lined heat shrink. Mil-Spec Teflon coating wiring. Most sensors identified with Raychem yellow labels with clear shrink. OEM, Deutsch, Bosch, GM, etc. connectors...all brand new, new OEM pins, etc. when I built it. The car had an OEM cluster in it so the harness comes with extra wires on the Deutsch connector for the dash indicators. I will provide a complete wiring pinout for all the sensors. Comes with OBD1 ecu connectors, but they can be changed out if needed. It has been wired for additional Bosch/AEM pressure sensors but also includes all of the following sensor plugs wired in:
OBD2 Alternator
OBD1 Distributor
Fan Switch
Starter Solenoid
Dash Water Temp
ECU Water Temp
VTEC Solenoid
VTEC Pressure Switch
Ground
Bosch MAP Sensor
Honda TPS
Turbo Compressor Pressure Bosch Sensor
Turbo Exhaust Back Pressure Bosch Sensor
Crank Case Pressure Bosch Sensor
VSS
Oil Pressure Bosch Sensor
Dash Oil Pressure Light
Intake Air Temp Honda
ID1000 Injectors
Fuel Pressure Bosch Sensor
OBD1 ECU
I can add a charge harness for an additional $40 if needed.
Price = $500
Old Aug 26, 2013 | 03:12 PM
  #73
ekslammed's Avatar
Means of contact: call text pm
Price: $400 will ship
Description:
b series t3 AFI ramhorn 44mm wasnegate vband flanged - was only
On car for about a month- has dyno time and about 4 track passes! Lmk if you have any questions! Call or text anytime (980) 254-7818
400.00 picked up but I am willing to ship
Pictures:
Old Aug 26, 2013 | 04:28 PM
  #74
carbon fiber coupe's Avatar
call/text for parts
513 668 4855
For sale type r / b16 supercharger kit custom intake .. I think it's a Magnus charger it's in really good shape comes with all the hardware to install also has after cooler kit and 2 pulley $2000 obo
gator axels b series $300 and stock b series axels
00 Acura type r transmission 4.4 final drive LSD no grinds shifts perfect $1000 obo
parts are in cincy ohio, prices are plus shipping (don't prefer to ship but buyer pays for shipping/packaging/time/materials)
http://www.flickr.com/photos/52620783@N06/9601318501/http://www.flickr.com/photos/52620783@N06/9601318501/ by http://www.flickr.com/people/52620783@N06/, on Flickr
http://www.flickr.com/photos/52620783@N06/9601317441/http://www.flickr.com/photos/52620783@N06/9601317441/ by http://www.flickr.com/people/52620783@N06/, on Flickr
http://www.flickr.com/photos/52620783@N06/9604553752/http://www.flickr.com/photos/52620783@N06/9604553752/ by http://www.flickr.com/people/52620783@N06/, on Flickr
Old Aug 27, 2013 | 06:49 AM
  #75
JdM iGeN's Avatar
My loss is your gain. Up for sale are my FIC 2150cc BlueMax Injectors (K-Series).
These injectors have less than 100 miles on them and were recently sent to FIC for a flow test and cleaning. All injectors are matched within 0.5%!
$600 shipped anywhere in the US!! - PM or Text 786-281-9472
Additional pics available upon request.
