X-rated material inside
Old Aug 31, 2003 | 11:31 PM
  #51
GSteg's Avatar
blah..RE lists minimum box size for their sub. 2 cube for a 15" is kinda small don't u think? 3 cubes..3 cubes... lol
u can probably build the 1.3 cube box the same way elemental design recommends for the A-series. that long snake port for the lack of terminology. lol. try passive radiator yet?
Old Aug 31, 2003 | 11:38 PM
  #52
vteg's Avatar
New User
Default Re: (GSteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">blah..RE lists minimum box size for their sub. 2 cube for a 15" is kinda small don't u think? 3 cubes..3 cubes... lol
u can probably build the 1.3 cube box the same way elemental design recommends for the A-series. that long snake port for the lack of terminology. lol. try passive radiator yet? </TD></TR></TABLE>
Long snake, thanks for the compliment.
Yeah it was a 30 inch port. Ported 12's should be atleast 2 cubes IMO. Easier to deal with.
The 2 cubes will surprise you though. Also if you do the plots, you will see that there is not much of a difference above 2 cubes, unless you are a person that worries about box q. I don't personally, since a car will screww that up anyway.
Old Sep 1, 2003 | 07:27 AM
  #53
GSteg's Avatar
Default Re: (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">
The 2 cubes will surprise you though. Also if you do the plots, you will see that there is not much of a difference above 2 cubes, </TD></TR></TABLE>
well durr..plotting programs (like WinISD) only shows anehoic response which is completely thrown out the window when u put the sub into the car. i can show u an example of why it's thrown out the window, but its a long example and you know how lazy i am to type a really long response..that is unless i can find a way to cliffnote it. ahaha.
Old Sep 1, 2003 | 10:58 AM
  #54
vteg's Avatar
New User
Default Re: (GSteg)
Transfer function ownz you
Old Sep 25, 2003 | 11:54 PM
  #55
vteg's Avatar
New User
Default Re: (vteg)
Well I started screwing and gluing last weekend. I just need to put on the front, top, cut holes and carpet. Basically 2 hours of work at most left if I take my time. After I put in my alarm on saturday. I will put in the box. I will try mounting my amp in the hole in the side where the stock sub goes. I saw someone else that had done that. Very stealth
The box looks menacing though. I am afraid of a puppy or a cat thinking the port is it's home.
mv1luv
Audio / Security / Video
Jun 4, 2008 05:11 AM
Worldsport
May 10, 2008 08:41 PM
AlienKrOZ
May 29, 2007 06:37 PM
DBAl
12
Jul 11, 2006 12:05 PM
romoracing
Apr 16, 2006 12:58 PM
