X-rated material inside
I just got through demoing
my new sub. First of all, I hooked it up and put it in the box. I connected amp. Got a wierd buzzing noise, and thought I wired the vc's backwards or something. I pulled the sub(my back), after 30 minutes or so of testing I find that one channel on my 1500DR is noisy. The TDX owned the ARC one more time on it's death note I guess
Sooo, I rewire the sub for 1 ohm and hook it to the good channel of my arc for now. I notice that the sub is damn loud considering volume level. I start driving. On low notes I hear a bad rattle. I pull over and pull down the rear seat to investigate, it goes away. I turn it up more, it comes back. It is my hatch cover thing behind the rear seat resting on my box
I push the box back an inch. OK. All better now. More volume.
The sub sounds very good and loud. TDX still wins on the low end for now.
I push the box back an inch. OK. All better now. More volume.The sub sounds very good and loud. TDX still wins on the low end for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">The TDX owned the ARC one more time on it's death note I guess </TD></TR></TABLE>
Are you going to fix it yourself?
Well I changed my mind. I met up with Abert(ATF Kuk) yesterday. He is going to send may amp in for me. I removed the sub. OMG. It is heavy in the box. I put it on my scale once I got it inside. 90 pounds.
When I get back from vacation the ported box comes, and I will say goodbye to my trunk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">
Sorry for the late reply. I can squeeze an 18" high box in my trunk. The only hard part is getting it in there.</TD></TR></TABLE>
Do you use the hatch cover?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dallasyoung »</TD></TR><TR><TD CLASS="quote">haha you horndogs! Theres like 500 views just b/c it says "xxx inside"...
and I am one of the 500 lol.</TD></TR></TABLE>
I knew that topic would get some positive attention from the guys in here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Torridcivic »</TD></TR><TR><TD CLASS="quote">SO vteg what is the final review, SPL, SQ, does it respond quickly for a 18" you put it in a ported right?</TD></TR></TABLE>
i believe he putted it in a 2.3 cubic feet sealed box. can't remember though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">
i'm think about getting some brahma's, but i have a integra hatch not much to work with.</TD></TR></TABLE>
Brahmas =
Awesome woofers.
Brahmas =
Awesome woofers.
Well ATF got to listen to it in my "girly" box, I will have him post what he thought.
Considering the conditions that I have listened to it so far, 500 watts from half dead arc and small box, it blew me away. I can't wait to get this in a real box. I just got back from vacation today. I will try to build a ported enclosure this weekend. Hopefully my amp is back from ARC, again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">if you can't hear it before you see it then whats the point.....good purchase.
The brahma and xxx are like brothers
I am sure you will be very happy with it.
You don't think you have enough space in a teg hatch?
I am sure you will be very happy with it.You don't think you have enough space in a teg hatch?
It is a 15"
It just looks bigger than it really is
Final review will come once I get my amp back.
It is a 15"
welcome back shawn, yes, i heard the **** sub, its awesome. i cant wait to hear it when everything is perfect and ready to go. my only complaint other than shawn made me squeal is that it scares me. its ******* HUGE
hopefully when i get my amp and box, ill battle u with my 12" ARC. mine will burp, urs will swallow mine alive
. hopefully when i get my amp and box, ill battle u with my 12" ARC. mine will burp, urs will swallow mine alive
I spent the last 2 hours making cuts for the new box. Damn this thing is going to be huge. 4 cubes after sub displacement, tuned to 33 with 65 square inches of port area
ATF, tell Arthur I will be ready to battle.
damn you guys. if i hadn't taken apart my idmax..i would have battled too! now the voice coil rubs against the gap. gotta get some of that eh..what u call it..uh.."thing that re-centers the coil". lol. now it makes scratchy noises and i get IMD. whoopy!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg »</TD></TR><TR><TD CLASS="quote"> gotta get some of that eh..what u call it..uh.."thing that re-centers the coil". lol. !</TD></TR></TABLE>
I think that is called a recone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg »</TD></TR><TR><TD CLASS="quote">
no no no..reconing wouldn't help since all i did was unscrew the thing that holds the surround and the spider thing. hrm..still looking for that term. i remember david telling me something about it. a gauge! something like that.
</TD></TR></TABLE>no no no..reconing wouldn't help since all i did was unscrew the thing that holds the surround and the spider thing. hrm..still looking for that term. i remember david telling me something about it. a gauge! something like that.
thats the problem..charges..i don't have any money. ahaha. shipping on that thing will cost probably $15 or more and ID will probably charge at least 20. might as well do it myself and hope i center it exactly. ahaha. tight gap tolerance owns me. o_0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg »</TD></TR><TR><TD CLASS="quote"> tight gap tolerance owns me. o_0</TD></TR></TABLE>
Hey, let's keep this pg rated.
I think I sprained a tendon in my hand trying to pull the xxx out of my sealed box. I am feeling very wussy right now
My ported box is on hold right now. I need to measure the potential new trunk before putting it together.
Also, RE updated their website. And GSteg, my 2 cube after displacement sealed box is right on their sq sealed recommendation. They also suggested 4 cube ported. *Patting myself on the back*
To keep me busy, and keep my mind off my car while I play the waiting game, I built a 1.3 box tuned to 30 with 14.5 square inches or port for an arc sub. These small boxes are a pain in the ***. Arc must have no idea how hard it is to get descent port area on such a small box
I listened to it in ATF Kuk's car. Not a bad sub for the price.
