Subwoofer Stuffed or emptied?
Old May 29, 2007 | 08:21 AM
AlienKrOZ's Avatar
Default Subwoofer Stuffed or emptied?
is it better to filled the woofer box with the poly-fil stuff or leave it empty?
poly-fil
http://www.crutchfield.com/S-7...27808
Old May 29, 2007 | 08:41 AM
B18C_EJ8's Avatar
Depends entirely on whether the box you're using is larger or smaller than the subwoofer's airspace requirements...
Old May 29, 2007 | 09:06 AM
AlienKrOZ's Avatar
Default Re: (B18C_EJ8)
i have an eclipse 12" dual coil subwoofer. i think the box is a bit less then 1 cubic feet. this box might be smaller then what im suppose to use. just i need the trunk space.
Old May 29, 2007 | 09:47 AM
Tnwagn's Avatar
Default Re: (AlienKrOZ)
Polyfil effectively makes the sub think it is in a "larger" box. Not perfect, but it does help if the box is a little small.
Old May 29, 2007 | 04:06 PM
02 accord's Avatar
Default Re: (Tnwagn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tnwagn &raquo;</TD></TR><TR><TD CLASS="quote">Not perfect, but it does help if the box is a little small.</TD></TR></TABLE>
And at the same time it restricts the movement of (limited due to the small box) air inside the box leading to the sub running hotter.
Old May 29, 2007 | 06:35 PM
JSPECSIR's Avatar
Default Re: (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">
And at the same time it restricts the movement of (limited due to the small box) air inside the box leading to the sub running hotter.</TD></TR></TABLE> thats what its supposed to do. poly fil works by warming the air from the friction of the fibers rubbing together due to the vibrations of the woofer. when the air in the enclosure and the suspension on the woofer warm up it will move more freely thus acting like its in a slightly larger enclosure. imo and in my experience, to me the woofer seems to have a smoother sound also when using the poly fil. i use it in all of my personal sealed enclosures. you can listen to it both ways and then decide. and you can get it at wal mart, you dont have to order it from crutchfield.
Old May 29, 2007 | 06:37 PM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tnwagn &raquo;</TD></TR><TR><TD CLASS="quote">Polyfil effectively makes the sub think it is in a "larger" box. Not perfect, but it does help if the box is a little small.</TD></TR></TABLE>
the polyester fibers that make up the polyfill kinda "trick" the sub into thinking it's in a bigger box because the fibers help to absorb and dissipate heat within the enclosure.
it's a give-and-take
Worldsport
Audio / Security / Video
May 10, 2008 08:41 PM
romoracing
Apr 16, 2006 12:58 PM
FK00GSR
May 18, 2005 08:01 AM
zumiez007
12
Dec 2, 2004 01:14 PM
civic_speed99
Aug 16, 2004 07:05 PM
