testing a relay to see if it is functioning correctly
Old Aug 25, 2003 | 07:47 PM
Lei Siew Long's Avatar
Default testing a relay to see if it is functioning correctly
no luck on tech forum so, i thought i would give this forum a try.
i'm trying to test my horn relay to see if it has malfunctioned. do i test for voltage, continuity????
thank you
Old Aug 25, 2003 | 09:25 PM
WickedKP's Avatar
Default Re: testing a relay to see if it is functioning correctly (Hatch4urSnatch)
i really don;t think your relay went bad. it could but the failer rate is so low. press your horn button and listen for the relay click. if you hear it get a test light and test it at the horn wire if you don;t hear it click test it at the relay conection
Old Aug 25, 2003 | 09:35 PM
rjr162's Avatar
Default Re: testing a relay to see if it is functioning correctly (WickedKP)
grab a multi-meter that can test ohms. Stick the probes on both sides of the Coil (typically pins 85 and 86). It should read around 50 ohms give or take. The contacts on the switching part shouldn't go bad, so if the coil is good I'd check the line as someone said above to make sure it's got +12 when the horn button is pressed. Or you can do these steps vice versa of course
Old Aug 26, 2003 | 05:17 AM
realblag's Avatar
Default Re: testing a relay to see if it is functioning correctly (rjr162)
Whoa!!! The resistance of the coil can read almost anything depending on the type of relay. I just grabbed one off the shelf and the coil read 75ohms. There will be resistance but the only safe thing to say about it is that it wont b a single digit number. The contacts are what go bad. Just before the contacts fully close there is a brief (milliseconds) arc. This wears out a relay. Also, all metel corrodes. Even if the relay is not used very much, it may be bad. Get the help of a buddy to push the horn button while you check for 12v at the horn.
Old Aug 27, 2003 | 08:00 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: testing a relay to see if it is functioning correctly (realblag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realblag &raquo;</TD></TR><TR><TD CLASS="quote">Whoa!!! The resistance of the coil can read almost anything depending on the type of relay. I just grabbed one off the shelf and the coil read 75ohms. There will be resistance but the only safe thing to say about it is that it wont b a single digit number. The contacts are what go bad. Just before the contacts fully close there is a brief (milliseconds) arc. This wears out a relay. Also, all metel corrodes. Even if the relay is not used very much, it may be bad. Get the help of a buddy to push the horn button while you check for 12v at the horn.</TD></TR></TABLE>
Well put
I go through a lot of relays because in the old school days, I used to do a lot of ambers for the street racers. Ofcourse, using these BOSCH relays for turn signals will put them through hell and sometimes go out in as fast as 6 months with quick blinks.
BTW, the horn trigger is usually Negative (-). So put the clamp of your test light on the battery.
Old Aug 28, 2003 | 04:45 AM
nOOber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realblag &raquo;</TD></TR><TR><TD CLASS="quote"> Just before the contacts fully close there is a brief (milliseconds) arc. This wears out a relay. Also, all metel corrodes. </TD></TR></TABLE>
This is called "Pitting" we see it mostly on light flash relays.
do you have +12 and ground on the 85 and 86 when the horn button is pressed ?
Old Aug 28, 2003 | 03:57 PM
Default Re: testing a relay to see if it is functioning correctly (nOOber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nOOber &raquo;</TD></TR><TR><TD CLASS="quote">
i haven't tested the relay yet, but, should i have 12 volts between those two terminals?
will this be the correct procedure to test if the horn is getting 12 volts?: unplug the harness on the horn and put the positive and negative probes on each terminal to see if it is receiving 12 volts when someone pushes the horn?
Old Aug 28, 2003 | 04:00 PM
so, if i understand this correctly, i should either have 50+ ohms between terminals 85 and 86 or 12volts? and i have anything that is 50+ ohms, the relay is in good working order?
Wildwilly3
Mar 5, 2019 04:41 PM
4gen5thtime
Apr 22, 2009 03:46 PM
BigDaddyRich
Mar 30, 2005 10:05 AM
Lei Siew Long
Aug 25, 2003 08:40 PM
T25 civic
Nov 18, 2002 07:23 PM
