How to test the main relay?
Old Nov 18, 2002 | 04:41 PM
T25 civic's Avatar
Default How to test the main relay?
I've been having trouble diagnosing the troubles I've been experiencing so now I'm checking my main relay. Is there any kind of test with just a test light or battery power that I can do (I have no ohmmeter) to see if the relay works?
Nick
Old Nov 18, 2002 | 04:52 PM
Desslok's Avatar
Default Re: How to test the main relay? (T25 civic)
I would try putting 12 volts to the trigger wires and listen for a click. If it doesn't click you know it's bad, if it does click it is still suspect and you need to find an ohm meter.
Old Nov 18, 2002 | 04:58 PM
T25 civic's Avatar
Default Re: How to test the main relay? (sp)
Do you hapen to know which ones are the trigger wires?
Nick
Old Nov 18, 2002 | 05:03 PM
Desslok's Avatar
Not w/out the Helm's or if it has a picture on it it might have two terminals with a squiggly line connecting them, that represents the trigger coil. Sometimes they have the diagram etched on them somewhere.
Old Nov 18, 2002 | 07:23 PM
T25 civic's Avatar
I figured out how to test it and the relay is good. but the fuel pump fuse isn't sending power to the relay. I wired in a fused jumper wire and it turned the fuel pump and AFC on, but it still won't start. I'm not getting spark. I still have no dash lights and I don't know how to test if the ecu is powering up.
Nick
Wildwilly3
Mar 5, 2019 04:41 PM
wood
Oct 8, 2009 02:36 PM
4gen5thtime
Apr 22, 2009 03:46 PM
BigDaddyRich
Mar 30, 2005 10:05 AM
Lei Siew Long
Audio / Security / Video
Aug 28, 2003 04:00 PM
