Sub Problem Again
Old Oct 20, 2009 | 07:01 PM
bmxkills's Avatar
Default Sub Problem Again
Alright, so my subs cut out sharp corners, or decent bumps (like train tracks). I have to turn my car off for a second, and then turn it back on to get my subs working again. This is a recent problem. I checked all the wiring, minus the wiring harness for the head unit, and nothing is loose. I'm a noob at this, so any guess?
Old Oct 20, 2009 | 08:53 PM
KRock459's Avatar
Default Re: Sub Problem Again
turn on short is my guess. Most head units will loose power on the remote circuit if it is overloaded or shorted to ground, it will return after the HU is power cycled. Make sure it isnt pinched inder the sub enclosure.
Kirk R
Old Oct 20, 2009 | 09:02 PM
AllMotorDC4's Avatar
I'd say check your ground amp and deck ground. Mine used to cut off when i'd hit bumps and it turned out to be the deck ground wasnt secure.
Old Oct 21, 2009 | 02:39 PM
Teg LS's Avatar
what wiring did you check?
bmxkills
Audio / Security / Video
Oct 13, 2009 06:31 PM
crux131
Apr 11, 2007 10:49 PM
JoshuaVTEC
Aug 30, 2006 10:36 PM
1.8gsrcivic2000
Jan 20, 2005 12:32 PM
RTE117
Oct 1, 2004 08:02 PM
