question for the wire experets (integra)
Old Sep 25, 2007 | 01:04 PM
climb_on's Avatar
Default question for the wire experets (integra)
anyone know what this wire is for?
its blue with white/greyish dots its located coming out of the firewall on the driver side. comes out to the connectors of the main wiring harness but doesnt connect to anything just to a rubber cap.
the car is a 2001 integra
here is an inlustration done by a 6 yr old
Old Sep 25, 2007 | 01:17 PM
climb_on's Avatar
Default Re: question for the wire experets (climb_on)
moved it to the teg section
feel free to delete this one mods
Old Sep 25, 2007 | 02:00 PM
B18C_EJ8's Avatar
Is it in the engine bay or under the dash? You just say it comes from the firewall...
If it's under the hood, it's the tach test connector.
If it's under the dash, sorry, can't help you.
Old Sep 25, 2007 | 04:13 PM
fcm's Avatar
fcm
Old Fart
Also would like to know if that's under the dash or in the engine bay?
Also think it's the tach test lead, I will look in my 94LS.
Old Sep 25, 2007 | 05:40 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: question for the wire experets (fcm)
Its for the optional fog light harness. There is one in the engine bay located next to the driver headlight. Its the same wire.
Old Sep 25, 2007 | 09:00 PM
climb_on's Avatar
Default Re: question for the wire experets (wrx-killer-Sti-eater)
sense i got more replys here i guess i'll answer some question
its under the hood right next near the fire wall along with the other plugs for the main wiring harness.
the reason im asking is that its been cut and re routed back into the car. i have an alarm so not sure if it has to do with that?
thanks
Old Sep 25, 2007 | 10:13 PM
CarbonizedDX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by climb_on &raquo;</TD></TR><TR><TD CLASS="quote">
That'd be your Tachometer service wire, you don't need to extend it...
Old Sep 26, 2007 | 01:32 AM
Default Re: question for the wire experets (CarbonizedDX)
sorry for the mis information. I took it that you were saying it from the inside of the car. The one your talking about is the tach. It could be routed back in the car for remote start. Or ran to the tach because of a lazy install
Old Sep 27, 2007 | 09:59 AM
climb_on's Avatar
ok that would make sense now cause the alram is a remote start model
thanks you
jmall8691
May 11, 2011 07:17 PM
Canadian_EF
Nov 8, 2010 12:59 PM
ATX45
Apr 30, 2006 09:14 PM
pnltnc
Apr 17, 2004 10:04 AM
