tack hook up
Re: tack hook up (pnltnc)
Check the FAQ thread, it shows exactly where it is. Its in a harness near the firewall I do believe.
EDIT: Check this
https://honda-tech.com/zero...98906
EDIT: Check this
Re: tack hook up (sol2nr)
Do you already have a stock tach in your dash bezel? if so try this. Take the bezel out. disconnet the plug in from the tach. look at all the wires. you will see a blue wire that should have like silver dash marks goin down one side. or at least 1 dash mark by the end. look for this wire. strip the end of the green wire. and shuv it into the connect slot of the blue wire. start your car and see if it works.
let me know.
let me know.
HondaCivicSiR1
22
12-13-2004 10:38 AM
DRAG14ciVHBKSI
08-14-2002 06:30 AM
