question about what amp is compatable with my sub
Old Sep 17, 2007 | 03:58 PM
Slo_Accord's Avatar
Default question about what amp is compatable with my sub
I have a dual voice coil 2 ohm type r sub. do i need a mono amp, 2 channel? can i switch over to i ohm. im kinda a noob when it comes to this so anything will be greatly appreciated. thanks
Old Sep 17, 2007 | 05:43 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: question about what amp is compatable with my sub (Slo_Accord)
The best thing would be to put the size of the sub so we can find out how much puwer you need. Is it 12, 10, 15?
Old Sep 17, 2007 | 08:46 PM
s13_240sx_92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo_Accord &raquo;</TD></TR><TR><TD CLASS="quote">I have a dual voice coil 2 ohm type r sub. do i need a mono amp, 2 channel? can i switch over to i ohm. im kinda a noob when it comes to this so anything will be greatly appreciated. thanks</TD></TR></TABLE>
It all depends on how you want to wire up your sub and what your budget is.
if you use a two channel amp and you are not bridging it you MUST run the same signal into both channels! If there is a stereo signal going into the speaker will slowly (or quickly) self destruct.
In general amps that can handle lower ohms will be more expensive.
Old Sep 18, 2007 | 01:19 AM
Default Re: question about what amp is compatable with my sub (s13_240sx_92)
Well since there is no model number here are your options. Your sub can be ran as a 1 ohm sub or a 4 ohm sub. Depending on if you wire the vc in series(4 ohm) or parallel(1ohm). You need a mono amp that will puts out your speakers rms imput in either a 1 ohm load or a 4 ohm load. Or find a 2 channel amp that you can bridge in to a 4 ohm load that will provide the rms power to your sub. There are not to many 2 channel amps that are cheap that will be bridge to a 1 ohm load.
Old Sep 18, 2007 | 10:43 AM
Slo_Accord's Avatar
its alpine 1222d. so its a 12 inch. 1500 watts max, 500 rms. so would these amps work?http://cgi.ebay.com/ALPINE-MRD...wItem =- - - - - =http://cgi.ebay.com/NEW-DUAL-1...wItem......thanks
Old Sep 18, 2007 | 12:39 PM
Default Re: (Slo_Accord)
did you ready anything above?
You need a mono amp........ thats 500 watts rms @ 1 ohm
or
You need a mono amp........ thats 500 watts rms @ 4 ohm
or
you need a 2 channel amp........ thats 500 watts rms bridge @ a 4 ohm load
or
you need a 2 channel amp................ thats 500 watts rms bridge @ a 1 ohm load, this is going to be the expensive one to use or find.
None of the amps that you posted will work. Here are a couple that will work
j/l audio 500/1
Alpine MRP-M850
mtx 4501
this will get you on your way to get your sub playing. There are more out there so find a budgt and pic out a amp
Old Sep 18, 2007 | 04:57 PM
Slo_Accord's Avatar
^ That was incredibly usefull. thanks
Old Sep 18, 2007 | 08:10 PM
wooooo, if you did not get that we were going to vote you off h-t
Old Sep 19, 2007 | 12:31 PM
Slo_Accord's Avatar
Haha. i just see it as, if a amp says 250 rms x2 at 2 ohm, then its 500 total. and i dont really get all that channel and ****. im seriously a noob to the extreme when it comes to amp/sub stuff
thecruzs2007@yahoo.com
Audio / Security / Video
Nov 25, 2009 11:47 AM
Accord1234
Feb 14, 2008 05:05 AM
rockin_remz
10
Mar 14, 2006 06:36 PM
Orpheus1985
Jul 31, 2005 04:11 PM
SSBP DC2
Apr 18, 2003 12:22 AM
