Ohms
Old Jul 31, 2005 | 09:42 AM
Orpheus1985's Avatar
Default Ohms
Question about ohms. If I have 2 subs that have 4 ohms and i wire them parallel, i now have 8 ohms but if i wire them serial i still have 4, is that correct? Also, should the ohms on the amp match that of the combined subs?
Old Jul 31, 2005 | 10:58 AM
NiPBoi's Avatar
Default Re: Ohms (Orpheus1985)
the amp adjust to what ohm ur subs are...isnt it if u run 2 4ohms parallel u get 2 ohms??? and if u run them in series is when u get 8 wheres fcm hes slacking today...
Old Jul 31, 2005 | 11:14 AM
8520's Avatar
Default Re: Ohms (NiPBoi)
It's nothing to do with the amp. It's all to do with the wiring. I can't seem to find the website with the ohm calculator though.
Are your subs dvc?
Ideally you want to get your amp down to 1ohm (if it is 1ohm stable )
Old Jul 31, 2005 | 12:04 PM
I've got 2 Kicker Comp 05C12 12" 4-ohm subwoofers and a 1600W, bridgable 2 or 4 channel stereo amp, 2 ohm stereo stable 4X400W max. Will that amp successfully power the subs?
Old Jul 31, 2005 | 01:57 PM
8520's Avatar
Default Re: (Orpheus1985)
yes
Old Jul 31, 2005 | 02:12 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Orpheus1985 &raquo;</TD></TR><TR><TD CLASS="quote">Question about ohms. If I have 2 subs that have 4 ohms and i wire them parallel, i now have 8 ohms but if i wire them serial i still have 4, is that correct? Also, should the ohms on the amp match that of the combined subs?</TD></TR></TABLE>Other way around, kind of, when you parallel 2 4ohm speakers the load is 2ohms, if you wire them in series it will be 8 ohms http://www.the12volt.com/caraudio/boxcalcs.asp 94
Old Jul 31, 2005 | 04:11 PM
8520's Avatar
Default Re: Ohms (fcm)
This one's better -
http://www.the12volt.com/carau...s.asp
And it's the one I couldn't remember where it was. Thanks for the help
GroundZer0 336
Audio / Security / Video
20
Aug 30, 2003 04:27 AM
cd5_2NR
Apr 24, 2003 02:02 PM
Vp Special K
Sep 30, 2002 09:56 PM
vtec-outlaw
Feb 4, 2002 12:45 PM
woodog
Dec 17, 2001 11:08 PM
