SPDT Relay
Old Sep 19, 2007 | 04:36 PM
95SE's Avatar
Default SPDT Relay
When issued a "pulse" does a 2-pole relay "switch" and stay or switch and return to a resting state or closed state?
I am trying to figure out a way to wire JDM folders without the OEM relay, ie DIY relay.
Pulse -> relay switches -> allow signal for mirror close
Next consecutive pulse -> relay switches -> allow signal for mirror open
Next...... close
If someone knows how to make the relay for the folding mirrors please let me know.
T
Old Sep 19, 2007 | 04:39 PM
B18C_EJ8's Avatar
Relays only activate for as long as voltage (or ground) is applied.
Old Sep 19, 2007 | 04:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: SPDT Relay (95SE)
No you can not just use a relay, the one that comes with the mirrors will be 2 relays, [polarity reversing] or there will be one relay and polarity reversing limit switches, probably a relay and 2 load sensing limit switches.
You could do it with two SPDT relays, [wired for polarity reversing] a SPDT rocker, [momentary] switch and a timer circuit. 94
dalek
Dec 26, 2007 12:21 PM
GS8HFL21
Nov 9, 2005 06:56 AM
dunkd
Sep 5, 2003 08:58 AM
