Amp
Old Feb 13, 2008 | 08:14 PM
Accord1234's Avatar
Default Amp
I saw sub and amp packages showing class D sub woofers amps that are 1 channel and come with 2 subs. If the amp only has connections for 1 speaker how do you hook it up. Just take both positives and both negatives together. I was looking at this amp for my 2 12" dual voice coil subs.
http://cgi.ebay.com/ebaymotors...7.m32
Modified by Accord1234 at 9:26 PM 2/13/2008
Old Feb 14, 2008 | 04:27 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Amp (Accord1234)
Here are the power specs for the amp in question.
* 400 Watts x 1 Channel @ 4 Ohms
* 800 Watts x 1 Channel @ 2 Ohms
* 1200 Watts x 1 Channel @ 1 Ohm
How you wire your speakers will determine what the resistance (ohms) your amp will see. With 2 DVC speakers you should be able to wire them up for 16-8-4-2 or 1 ohm. What kind of speakers do you have?
Old Feb 14, 2008 | 05:05 AM
Accord1234's Avatar
Default Re: Amp (White Smoke)
There 12" Infinity Reference 1200 watt peak, 300 watt rms each dual voice coil. I used to have them hooked up to a 1200 watt amp that was bridgeable 500 to 1 at 4 ohms in a sealed box. I dont think it was powerfull enough for my speakers. I wanted to use those speakers over and then use this amp at no more then 2 ohms. Because this amp is actually 800 x1 at 2 ohms that means each speakers will acutally get about 400 watts each peak right?
Or would a speaker set at 2 ohms be better.
http://www.crutchfield.com/App...p=111
Modified by Accord1234 at 6:18 AM 2/14/2008
superdat1
Audio / Security / Video
13
Jan 4, 2008 10:42 AM
ilikeric3
30
Sep 2, 2006 02:21 PM
rockin_remz
10
Mar 14, 2006 06:36 PM
cd5_2NR
Mar 18, 2004 06:17 PM
Jonathan_ED3
11
Jul 9, 2003 10:33 AM
