Prob with speakers
Old Jan 9, 2006 | 11:50 AM
RobertM's Avatar
Default Prob with speakers
Ok iv got a weird prob
All right My Subs Work but nothing else The stero system has been in the car for about a year and a half with no prob and sudenly as i was geting on the highway my other 4 speakers stop working all at once and just sub are hiting
If i turn the Amp on high pass i can still hear the voices out of the subs so i dont understand whats wrong
This is whats all connected:
2 JL 10's
Allpine HU
Pioners spekers in the doors and rear deck
Kicker Amp
Old Jan 9, 2006 | 11:57 AM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: Prob with speakers (RobertM)
I had the exact same problem! But it just dissapeared , I have no clue why it did that. After that , my subs would cut out and the full ranges would stay on. Then my headlights would blink with the bass , then all of a sudden . . . . nothing was wrong and my bass hit harder then ever. WTF?
Old Jan 9, 2006 | 12:05 PM
MLD211's Avatar
You will have to be more spicific about your setup. How many amps do you have? Are your interiors running off the deck amp or external amp? Obviously what ever source is powering your interiors has the problem. Most likey a grounded out speaker wire a blown speaker or a bad amp.
Old Jan 9, 2006 | 12:08 PM
RobertM's Avatar
Default Re: (MLD211)
The Amp is only connected to the subs And theres only one Amp
The Rest is pluged into the HU
Old Jan 9, 2006 | 12:28 PM
MLD211's Avatar
Your internal amp in the HU has a protection circuit that will shut the amp down in order to protect it from blowing. One of your speakers and speaker wire are causing the amp to shut down. Best way to find out which one is to disconnect each speaker one at a time with the radio on at the back of the deck. IE cut the wires for the front right, no sound? reconnect and cut the wires for the front left. I fthe sound come back on after cutting one of the speakers you know where you problem is. Check the speaker to see if its blown or the wire connected to it have a short. If none then its possible the internal amp in the radio is bad. Mine went bad in my alpine no biggy just connected a 4 ch amp the RCA preouts should still work.
Old Jan 9, 2006 | 12:34 PM
RobertM's Avatar
Wow that helps alot! i better get to work Il update on how it goes
Old Jan 9, 2006 | 12:58 PM
RobertM's Avatar
Default Re: (RobertM)
All right the internal amp must be bad
The only other amp i have is broken maybee i should make another thread on how to fix an amp
Old Jan 9, 2006 | 01:05 PM
MLD211's Avatar
With all the speakers disconnected, try using a uninstalled speaker you know works and attach it right at the back of the deck if still no sound then yeah your amp is bad in the deck.
Chefduncan
Audio / Security / Video
23
Dec 27, 2009 07:34 PM
pinks11
Nov 19, 2007 07:04 AM
Torridcivic
Sep 23, 2003 07:49 PM
Feuerraeder
Dec 24, 2002 09:06 AM
