Does an amp make a difference?
Old Dec 25, 2009 | 06:50 PM
Chefduncan's Avatar
Default Does an amp make a difference?
So i just recently installed some infinity reference 6.5 speakers in the front doors of my civic along with alpine type g 6x9s in the back. When i turn my music all the way up at the highest/lowest points in songs sometimes my speakers make a beep and cut out. They stop once i turn them down. I have 150hz bass blockers on the front but not the rear speakers. Both are rated for 75 rms but are only getting the power from the headunit. Will an amp solve this problem?
Old Dec 25, 2009 | 06:53 PM
edzy's Avatar
Default Re: Does an amp make a difference?
Yes an amp will solve the problem
take those bass blockers off too
Old Dec 25, 2009 | 07:07 PM
Chefduncan's Avatar
i was told that the bass blockers would help stop with bass distortion? Also do you know of any good cheap 4 channel subs that i could use to run these speakers?
Old Dec 25, 2009 | 07:12 PM
edzy's Avatar
your speakers should be able to get down to 80hz with no problem
unless they're absolute crap
what are the model numbers
Old Dec 25, 2009 | 07:13 PM
Chefduncan's Avatar
they are the infinity 6032si.
Old Dec 25, 2009 | 07:16 PM
edzy's Avatar
you're missing out on alot of bass with a 150 hz high pass
this amp would work
http://www.woofersetc.com/p6839/DSC4...-Amplifier.htm
Old Dec 25, 2009 | 07:21 PM
Chefduncan's Avatar
I was wondering why i had only a little bit more bass increase from this swap. looks like ill have to take those off soon.
Old Dec 25, 2009 | 07:22 PM
edzy's Avatar
go for a 100-120hz high pass on those infinitys
they'll get down to 80 with no problem but will crap themselves once u start to turn the volume up since they aren't that great of a speaker..
Old Dec 25, 2009 | 07:27 PM
Chefduncan's Avatar
alright, thanks for the help. I also was wondering i am looking to hook up a 10 inch kicker comp (i know its bad quality) is there any amp i could use to power that and the 4 speakers?
Old Dec 25, 2009 | 07:30 PM
edzy's Avatar
that sub would shine decently in a custom built ported box
it would be smarter if u invest your money into your front stage instead of buying a sub
Old Dec 25, 2009 | 07:34 PM
Chefduncan's Avatar
i actually had the sub given to me with a kicker zx.300 amp, I actually have a ported box built to a little larger then the factory specifications. I am looking into buying a new headunit asap.
Old Dec 25, 2009 | 07:40 PM
edzy's Avatar
oh then you're good then
what hu are u currently using?
Old Dec 25, 2009 | 07:42 PM
Chefduncan's Avatar
JVC kd-r300, not sure what direction to go in, i know pioneer and kennwood and alpine are all good but i dont know exaclty what i want to spend or what im looking for
Old Dec 25, 2009 | 07:46 PM
edzy's Avatar
You gotta figure out a budget then go from there...
For now, amp the infinity speakers. If u just change the hu now and don't amp the speakers, you'll run into the same problems since the internal amp just doesn't provide enough power for aftermarket speakers.
once you're done with that, read around various car audio forums such as
http://www.caraudio.com/forum
http://www.diymobileaudio.com/forum/
create a set budget and see what's the best you can get with that given budget.
Old Dec 26, 2009 | 12:40 PM
mrdeadman's Avatar
They let me pick
I would say that because you are turning them up real loud, I would amp the speakers first. Then get either a clarion or an alpine hu.
If you didn't listen to your music so loud as to where you overdrive the hu's internal amp, then you could just get a new hu and be fine.
Old Dec 27, 2009 | 10:55 AM
Chefduncan's Avatar
yeah im looking at getting a kicker zx350.4 it seems to be about the perfect fit. both speakers are 75 rms and this puts out 60 so they will be a little underpowered but its about the best fit i can find. I am considering spending about 200 or so on a headunit you think i will be able to get something nice for that?
Old Dec 27, 2009 | 11:07 AM
mrdeadman's Avatar
They let me pick
As long as you don't turn them up so loud that they continue to "clip" again, you will be fine. If you like you music really loud, I would suggest something with at least 75wrms, like this:
http://www.onlinecarstereo.com/CarAu...t_DSC4125.aspx
You can get some very nice hus for 200 nowadays, like the clarion dxz785usb, I have this one and I really like it. I also have the 765, it does not have a usb port but it sounds great as well.
I would search around, some of them may have features you don't want/need.
Old Dec 27, 2009 | 11:11 AM
Chefduncan's Avatar
yeah i feel like after i amp them i will be good with how loud they get. They get pretty loud right now but will clip. Yeah i really would just like a hu that has an aux or the ipod control and 2 outputs for amps. Those are really all i want, A nice eq wouldnt hurt either.
Old Dec 27, 2009 | 11:46 AM
mrdeadman's Avatar
They let me pick
I'll let fcm give you a couple of alpines you can look at too. I'm not familiar with them like he is.
Old Dec 27, 2009 | 12:09 PM
edzy's Avatar
kicker amps only do their rated power @ 14.4 volts
keep that in mind...
the mb quart dsc amps are the best bang for buck amps on the market right now, and maxxsonics will be discontinuing them soon..so pick one up asap
Old Dec 27, 2009 | 03:36 PM
mrdeadman's Avatar
They let me pick
Alternator outputs 14.4 +-
Old Dec 27, 2009 | 03:55 PM
edzy's Avatar
@ idle?
Old Dec 27, 2009 | 06:51 PM
Chefduncan's Avatar
im unfamilar with the quarts. Have you used them before or know anyone that has? i would definately be willing to spend a little more if it actually saved me in the long run. As for the kickers i dont think i will need the whole 60 watts that it will be putting out since that would alot more than my hu is putting out right now.
Old Dec 27, 2009 | 07:34 PM
edzy's Avatar
i've used the 480 and am currently using the 4125
i've got them both benched and they both did a little over rated power
best budget amps out right now imo
and they do their rated power @ 12 volts.
189 for an amp that does 125 x 4 and 500 x 2 bridged cannot be beat.
here's a link
http://www.woofersetc.com/p6837/DSC4...-Amplifier.htm
salaamq
Audio / Security / Video
Sep 26, 2012 04:23 PM
Cody2289
14
Feb 11, 2008 09:28 AM
pinks11
Nov 19, 2007 07:04 AM
Torridcivic
Sep 23, 2003 07:49 PM
