sub wiring questions
Old Jan 7, 2006 | 05:28 PM
mrdeadman's Avatar
They let me pick
Default sub wiring questions
i recently aquired another sub and amp. the amp i bought supposedly has overheating problems because it's so small. any suggestions on what to do to let it cool better? ill be running 2 amps off one 4g power cable with a splitter to 2 8g. one fuse in the 4g will be enough right? also would that set up be better or worse than running 2 8g power cables direct?
Modified by mrdeadman at 7:46 AM 1/8/2006
Old Jan 8, 2006 | 11:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: sub wiring questions (mrdeadman)
What exactly are you trying to do?
Are you going to be running 2 subs and 2 amps?
What are the are the makes and models of the amps and subs?
There is more then one reason an amp will run hot, the size of the amp is not necessarily on of them, too low of a load on the output is a more common problem, over-driving the amp in another, and poor power or grounds, or their connections is another. 94
Old Jan 8, 2006 | 02:00 PM
mrdeadman's Avatar
They let me pick
Default Re: sub wiring questions (fcm)
run 2 subs and 2 amps. both are reference series one is a 10, 1042 ones a 12, 1242. i have a bazooka ba1300 and an mtx one of the older ones supposedly 300w rms x 2 at 2 ohms.
Old Jan 9, 2006 | 09:33 AM
fcm's Avatar
fcm
Old Fart
OIC...... don't be surprised if it doesnt work, trying to get sub bass out of 2 diff. sized speakers and 2 diff. amps may end up sounding worse rather then better, IMO you would be better off with one or the other, or run the 10 as a mid bass and the 12 as a sub. 94
Old Jan 9, 2006 | 01:13 PM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> run the 10 as a mid bass and the 12 as a sub. 94</TD></TR></TABLE> that was partially the plan. im also experimenting here so dont be mean. this is why im going to have two amps instead of running them off one, that way i can adjust individually. so back to the original questions. any suggestions anyone?
Old Jan 9, 2006 | 01:22 PM
MLD211's Avatar
My guess is not that the amp has problems more likley the sub is not wired correctly. Is the sub single or dual voice coil? If subs are wired at to low of an impedance that will cause the amp to run hotter and go into protection.
Old Jan 9, 2006 | 01:36 PM
mrdeadman's Avatar
They let me pick
Default Re: (MLD211)
the guy at circuit city just said that they heat up quick. it is rated for 2 ohms and that is what ill be running it at, either that or 4, which it is also rated at, i haven't decided yet. also is there any way i could make something that would cool it down? like run a fan or something?
Old Jan 9, 2006 | 01:43 PM
MLD211's Avatar
Default Re: (mrdeadman)
Yes you can use simple computer case fans or the make cross flow fans. Heres a link to select products website they have a few fans. click on a-z products then fans.
https://selectproducts.com/html/frame2/frames2.htm
Old Jan 9, 2006 | 01:50 PM
mrdeadman's Avatar
They let me pick
what's a cross flow fan? it looks like it goes over the amp or something? also how would i go about hooking one of these up?
Old Jan 9, 2006 | 02:01 PM
MLD211's Avatar
yes it blow air in sort of a sheet across the amps or under. Simple switch or you could have it turn on with the remote turn on wire from the deck. Use a relay and connect as follows:
85 - Ground
86 - remote wire(+)
30 - 12volts
87 - (+) out to fans
Old Jan 9, 2006 | 02:21 PM
mrdeadman's Avatar
They let me pick
nevermind.
Modified by mrdeadman at 8:15 PM 1/9/2006
Yun_Ej2
Audio / Security / Video
Apr 25, 2011 05:07 PM
supracrx
Jun 7, 2006 07:34 AM
pnthr30
13
Jun 15, 2004 07:05 PM
101998
Nov 3, 2002 08:47 PM
JR_Si
Jul 20, 2002 09:49 PM
