Need help with Stereo
Old Sep 26, 2014 | 11:38 PM
Uljima's Avatar
Default Need help with Stereo
Need help with my aftermarket stereo, so, the red wire (ignition wire) has no power going to it when i turn on the key. I have also tried monitoring the power when the key turns on and there is also no power, and I have also tried to put my gps charger into the cig lighter, and yet nothing happens. The fuse for the Cig lighter isn't blown, and i have literally tooken out every fuse and none is blown. Any ideas ? Honda civic 2000 ek
Old Sep 27, 2014 | 12:33 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: Need help with Stereo
Check under hood fuses?
Old Sep 27, 2014 | 08:32 PM
Uljima's Avatar
yup none are blown.
Old Sep 27, 2014 | 08:35 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
have you checked for power directly from the key switch when in accessory position? maby it's just a bad key switch
Old Sep 29, 2014 | 04:45 AM
Acu's Avatar
Acu
sound like you have a wiring problem, something probably disconnected.
Old Oct 15, 2014 | 10:24 AM
MotoCARR's Avatar
May have a break in the wire somewhere. My personal experince is spend a little time trying to see if there is a break in it but if you have a few hours invested and no results, just run a wire to the key cylinder and connect the red wire off your radio to the yellow wire at the ignition.
Old Oct 17, 2014 | 07:06 AM
it should be obvious but are you also hooking up the memory wire? a lot of modern stereos are powered by the memory wire with the red power wire only being a trigger,even if it's not the radio won't power without the memory wire hooked up regardless
Old Oct 19, 2014 | 11:35 PM
Uljima's Avatar
Yes the memory is also hooked up. It's been like 3 weeks now I haven't found the problem yet
Old Oct 19, 2014 | 11:36 PM
Uljima's Avatar
It's has been like weeks now I sill haven't figure it out but I'll try this out and see if I can figure out the problem
Old Oct 20, 2014 | 02:44 PM
are you testing for voltage under load or just on an open circuit, digital meters are great, but will show voltage on a circuit that has a bad connection, and can't flow anything but a few miliamps. You need to put a load on the circuit then check voltage. Since the only thing on accessory position is the radio, it's very possible that the key switch contact is bad internally
Old Oct 25, 2014 | 01:46 PM
TypeRracer22's Avatar
simple solution is just run the red wire to your ignition switch problem solved
Old Oct 25, 2014 | 04:50 PM
it may be the ignition switch that has a bad connection in accessory, instead of rigging this find the problem and fix this
Old Oct 25, 2014 | 05:44 PM
if it was a bad ignition switch you wouldnt be getting 12v to the ignition and car will not start due to not receiving the signal to the ign wire to turn on fuel. so i think your ignition switch is fine
Old Oct 25, 2014 | 05:49 PM
it could be ur acc 2 wire on that vehicle that could be shorted. i do remote starts and when you dont hook up acc2 the radio does not turn on while car is started just a thought but i would diffently check the ignition switch for 12v in every position
Old Oct 25, 2014 | 06:53 PM
what does the accessory position on the switch have to do with the car not starting? there is more then one circuit in the ignition switch
Old Oct 25, 2014 | 11:44 PM
Ur right what else doesn't come on other then the lighter and radio when u put the car in accessorie
Old Oct 25, 2014 | 11:53 PM
How to replace the ignition switch or troubleshoot (Honda, Acura)
Check this link out to determine if ur switch is bad. Scroll down to the part where it says how to tell if ign switch is bad
efjones9
Audio / Security / Video
Jun 10, 2009 08:33 AM
MrBryan
May 28, 2007 04:27 AM
TomTomTuning
Honda S2000
13
Jun 15, 2006 02:16 PM
KrispyKreme
12
Mar 17, 2005 01:13 PM
tyflip2
Jun 14, 2004 03:08 PM
