why does my deck lose settings?
Old Mar 13, 2005 | 10:31 PM
KrispyKreme's Avatar
Default why does my deck lose settings?
every time i turn my car on i have to reset my settings on my deck, and my clock starts back at 1....how do i fix this???
Old Mar 13, 2005 | 11:14 PM
EGPrelude's Avatar
your power wire is probably wrong
Old Mar 14, 2005 | 03:42 AM
KamoteMan's Avatar
Default Re: why does my deck lose settings? (lshatch318)
did the deck turns on even the keys off? if it does, that's simple. check your wirings if you connect the yellow wire for acc maybe you put it all to the red wire( positive ) put the yellow wire from your hu it has label on it (ACC) on the yellow wire not on the red one
Old Mar 14, 2005 | 04:43 PM
CivicVP04's Avatar
If your wires are properly connected, you may have a blown fuse for the constant power (yellow) wire.
Old Mar 14, 2005 | 07:36 PM
Default Re: (CivicVP04)
the deck doesnt come on when my keys are off, and i have checked all the fuses....when i said clock im talkin bout the clock on my dash not the deck, so that seem wierd to me
Old Mar 14, 2005 | 08:10 PM
Nicknyce's Avatar
You have the yellow wire from your deck connected with the positive in the deck, which are both connected tothe power from the car.
Old Mar 14, 2005 | 09:25 PM
MechaniZm's Avatar
Your ACC and 12V+ wires are reversed. Switch them around. If he had a blown fuse/no constant, etc the deck wouldn't turn on. The described symtoms indicate *only* what I said. That, or a bitched head unit.
Old Mar 14, 2005 | 09:26 PM
MechaniZm's Avatar
Default Re: why does my deck lose settings? (MechaniZm)
And if your dash clock isn't working...you caused other problems and should have had a professional install it for you.
Old Mar 15, 2005 | 10:43 PM
thanks for the help fellas i guess the only left to do is to swith my red and yellow wires....
Old Mar 16, 2005 | 08:19 AM
MechaniZm's Avatar
Good luck with it...
Old Mar 17, 2005 | 12:53 AM
i hate the damn wires in my car. my hatch was made in canada and the colors of the wries are weird, i know the white/blue wire is either the constant or the switch...i guess it will just be trial and error til everything works
Old Mar 17, 2005 | 07:01 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch318 &raquo;</TD></TR><TR><TD CLASS="quote">i hate the damn wires in my car. my hatch was made in canada and the colors of the wries are weird, i know the white/blue wire is either the constant or the switch...i guess it will just be trial and error til everything works </TD></TR></TABLE>The wiring in US and Can. cars are the same, go to http://www.installdr.com for wire colors. 94
Old Mar 17, 2005 | 01:13 PM
Default Re: why does my deck lose settings? (fcm)
thanks man, looks like i have the ignition wire mixed up but the battery wire is right, cool, i hope my clock will start workin now
MrBryan
May 28, 2007 04:27 AM
sz9182
Audio / Security / Video
Apr 30, 2007 08:27 PM
j_DC2_m
Apr 14, 2007 04:32 PM
killacrx1
May 27, 2006 12:26 AM
itsJDMyo
Nov 24, 2003 01:02 PM
