hooking up multiple guages
Old Feb 20, 2004 | 10:01 AM
4doorex's Avatar
Default hooking up multiple guages
I didn't know what forum to put this in, since it's electrical, I thought I would try here.
I have four guages i want to install in my car, A/F, water temp, oil pressure , and fuel pressure, all electric. Where do i get the accessory power wire from? I had three of these guages installed in my other car and when I shared the acc wire with the radio and all the gauges my A/F guage didn't work any more. So any ideas?
Thanks
Matt
Old Feb 20, 2004 | 11:43 AM
Spider Man's Avatar
Default Re: hooking up multiple guages (4doorex)
Home Depot.
Old Feb 20, 2004 | 10:44 PM
4doorex's Avatar
Default Re: hooking up multiple guages (Spider Man)
haha
I didn't mean where to buy the power wire. I meant where do i get the wire in the car. Should i run a fused wire from the battery to a relay for each guage or is there an easier way?
Matt
Old Feb 21, 2004 | 04:58 PM
Eric R's Avatar
All these gauges can be powered from the ACC wires found in the main harness from the ignition switch. Run a fused line from the heavy gauge wire that shows 12V when you put the key in the ACC position and you're done. For the lights, do the same at the dash light comming from the parking light circuit.
fryman
Aug 30, 2009 07:48 PM
93egSLEEPER
Jul 12, 2009 04:54 PM
tyflip2
Jun 14, 2004 03:08 PM
killa_lude
Nov 19, 2003 01:32 PM
ash.zero
May 2, 2003 11:59 AM
