HELP!!! Battery/starter problem
Old Dec 12, 2005 | 07:48 PM
Kyle R's Avatar
Default HELP!!! Battery/starter problem
I decided to move my battery to my trunk (dry cell) in my 01 S2000 because it wont fit under the hood once I install my lovefab turbo kit. anyways, after the installation, all of the lights worked, but when i hit the start button, i heard a loud POP (i thought it might be a blown fuse) and everything went off. NOTHING in the car works at ALL. I checked the fuses, the battery is fully charged, there are no loose connections. Does anyone have any ideas? could it be ECU related?
Kyle Ritchie
Old Dec 13, 2005 | 11:55 AM
B18C_EJ8's Avatar
Well Kyle Ritchie, have you determined if you've got power going to the starter when you press the start button? Do you have power going to the starter solenoid?
Old Dec 13, 2005 | 01:17 PM
fcm's Avatar
fcm
Old Fart
Default Re: HELP!!! Battery/starter problem (herecomesboost)
Well if nothing works, I would guess a blown fuse, [main] or a bad connection, have you tested for power under the hood where you made the connection of the extended batt. lead to the place where the batt was connected when it was up front. BTW haw did you do that, what gauge is the wire/cable running from the batt. and where did you connect it? 94
Old Dec 13, 2005 | 06:17 PM
nsxxtreme's Avatar
Default Re: HELP!!! Battery/starter problem (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Well if nothing works, I would guess a blown fuse, [main] or a bad connection, have you tested for power under the hood where you made the connection of the extended batt. lead to the place where the batt was connected when it was up front. BTW haw did you do that, what gauge is the wire/cable running from the batt. and where did you connect it? 94</TD></TR></TABLE>
I second that a loud pop sounds like arcing. I assume you fused very close to the battery? yes? What value fuse or breaker did you use?
tvdc2
Jul 29, 2016 08:48 AM
fleschrod
Aug 4, 2015 08:57 PM
jimbomac22
Dec 24, 2011 08:41 AM
karatekid1981
May 18, 2007 09:21 PM
Heavy Pee
Jul 21, 2003 08:32 PM
