crossover ?
Old Feb 13, 2008 | 01:35 PM
BYAAH85's Avatar
Default crossover ?
I am not very knowlegable about audio components. Here is a couple of questions i hvae. I have a 94 integra with no tweeters, and i just got some new speakers and tweeters. I believe i have the wires for tweeters already. There is 2 wires that go into a clip that is not plugged into anything, so i am assuming that is it. My first question is do i need crossovers evnthough it is already wired up for tweeters. That is my only question as of now , but im pretty sure ill have more based on the feedback i receive. thanks
Anthony
Old Feb 13, 2008 | 01:39 PM
JSPECSIR's Avatar
Default Re: crossover ? (BYAAH85)
yes
Old Feb 13, 2008 | 11:50 PM
BYAAH85's Avatar
Default Re: crossover ? (JSPECSIR)
http://mobile.jlaudio.com/prod...d=125
I was goin through my owners manual for my jl speakers, and from what i gathered from it i think that it might have "built in" crossovers. sorry if that isnt the right wording. Page 2 on the adobe download manual is what im talkin about. If someone who is familiar with the terminology of car audio and knows what they are talkin about (because i dont) that would be a great help. Also in that pic on page 2 what is that black thing that is connected in between the tweeter and the speaker? is that the crossover? thanks again
Anthony
Old Feb 14, 2008 | 11:32 AM
BYAAH85's Avatar
bump
Old Feb 14, 2008 | 08:43 PM
BYAAH85's Avatar
hump
Old Feb 15, 2008 | 06:03 AM
fcm's Avatar
fcm
Old Fart
The "black thing" is the x-over, you will need to use it.
You do also know that the TR650-CSi is an over-sized 6.5" speaker and is not a direct fit into the stock speaker housings in the doors of your 94 Teg, right? 94
Old Feb 15, 2008 | 09:11 AM
BYAAH85's Avatar
Default Re: crossover ? (fcm)
yea im already not using the speker housings anymore. x-over = crossover right. i just want to make sure, so i dont buy an aftermarket crossover since i think i already have them(black thing). I'm just hoping They just look different than what i see online. basically i just want to know that i can run these properly with out having to buy crossovers if i dont need them. Thanks
Anthony
Old Feb 15, 2008 | 11:13 AM
fcm's Avatar
fcm
Old Fart
You do not need to buy x-overs, [crossovers].
If you got rid of the stock plastic speaker housings, what did you do to mount the JL speaker? 94
Old Feb 15, 2008 | 11:47 AM
Norb's Avatar
With oversized speakers, some will fit with spacers, and some you can't fit without modifying the door itself. Your going to have to hook up the factory crossover and just hook it up to the tweeter.
Old Feb 15, 2008 | 02:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Norb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Norb &raquo;</TD></TR><TR><TD CLASS="quote">With oversized speakers, some will fit with spacers, and some you can't fit without modifying the door itself. Your going to have to hook up the factory crossover and just hook it up to the tweeter. </TD></TR></TABLE> First, you do not have to modify the door itself unless you are installing bigger then over-sized 6.5" speakers.
Second, There is no factory x-over, [it is nothing more then a cap on the stock tweeter], the aftermarket speakers come with their own x-overs, [tweeter protectors]. 94
Old Feb 15, 2008 | 11:15 PM
BYAAH85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
If you got rid of the stock plastic speaker housings, what did you do to mount the JL speaker? 94</TD></TR></TABLE>
Right now i have some alpines mounted directly on the door. I will end up doing the same withe jl speakers, and i will also be cutting into my door panels for the tweeters. I'll take some pics once the install is done
Anthony
Old Feb 16, 2008 | 07:02 AM
fcm's Avatar
fcm
Old Fart
You should be replacing the stock plastic speaker housings with custom MDF speaker housings, or at least an MDF mounting plate.
You can not get a proper mounting surface when mounting directly to the door skin, you need an absolutely flat surface, you need an airtight seal around the speaker, and for best sound from the speaker it needs to be mounted to more mass then the doors sheet metal provides. 94
Old Feb 17, 2008 | 12:45 AM
BYAAH85's Avatar
thanks im lookin into the mdf stuff right now.
Jaynik
Audio / Security / Video
Jan 3, 2010 01:46 PM
bopbop93030
May 14, 2009 11:21 AM
cityslicker1606
13
Sep 16, 2007 05:52 AM
watacivic
Feb 16, 2006 09:00 AM
brads94accord
Mar 28, 2004 10:38 AM
