speaker harness question
Old Sep 14, 2007 | 12:32 PM
cityslicker1606's Avatar
Default speaker harness question
if i buy aftermarket speakers for my car can i plug them into the same place as the old speakers or do i need one of these
http://www.circuitcity.com/ssm...#tabs
will they sound like crap if i plug them into the factory wires
Old Sep 14, 2007 | 01:39 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: speaker harness question (cityslicker1606)
The speakers are only going to sound as good as the signal they are reciving. The stock speaker wires are good up to 40 watts. But I seen systems that used 50 rms watts thru factory wires that sounded great. And you would not even tell the diffrence. But thats were I draw my line and replace to bigger speaker wire. The adapters will be okay.
Old Sep 14, 2007 | 03:38 PM
Default Re: speaker harness question (wrx-killer-Sti-eater)
my car is old and they have 15w speakers in them can they still handle 40w
Old Sep 14, 2007 | 04:05 PM
fcm's Avatar
fcm
Old Fart
Yes the speaker wires can, the 15W speakers can also, just not for very long. 94
Old Sep 14, 2007 | 04:57 PM
Default Re: speaker harness question (fcm)
i have some 180 watt pioneers, and my head unit only puts out 52x4, will they still sound good or do i really need an amp.
Old Sep 14, 2007 | 06:33 PM
thats peak power. Whats the rms? and model numbers?
Old Sep 14, 2007 | 06:46 PM
this is what i got
Old Sep 14, 2007 | 07:10 PM
fcm's Avatar
fcm
Old Fart
You have 35W speakers... http://www.pioneerelectronics.....html
Now, what HU do you have? 94
Old Sep 14, 2007 | 07:13 PM
http://www.circuitcity.com/ssm...il.do
this is my headunit
Old Sep 14, 2007 | 11:17 PM
you will be fine with that headunit.
Old Sep 15, 2007 | 05:47 AM
ok thanks for the help
Old Sep 15, 2007 | 06:14 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
Your HU is 22W per ch into 4 ohms...
Audio
Continuous power output is 22 W per channel minimum
into 4 ohms, both channels driven 50 to 15 000 Hz with
no more than 5% THD.
Maximum power output ....... 50 W × 4
Load impedance ...................... 4 W (4 W to 8 W allowable) W should be ohms
Preout max output level/output impedance
.................................................. ... 2.2 V/1 kW 94
Old Sep 15, 2007 | 11:16 AM
to get the most out of these speakers will i need a small amp.
Old Sep 16, 2007 | 05:52 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cityslicker1606 &raquo;</TD></TR><TR><TD CLASS="quote">to get the most out of these speakers will i need a small amp.</TD></TR></TABLE>Yes. 94
kaivorth
Audio / Security / Video
Dec 13, 2016 01:43 PM
lee0149
13
Jan 7, 2009 08:47 PM
BoOsTiN Dc2
11
Mar 2, 2005 12:45 PM
all420
May 30, 2003 04:30 PM
