arm- roll up window, and window down on command.?
Old Jul 23, 2003 | 01:39 PM
weakGOODJunKieS.com's Avatar
Default arm- roll up window, and window down on command.?
my friends bros car can do this.. if your windows are down, and you arm your alarm system the windows would roll up, and on the remote you could roll the windows down using a free channel...
does anyone know how to wire this? im planning to buy the window up/down module.
Old Jul 23, 2003 | 02:00 PM
vteg's Avatar
New User
Default Re: arm- roll up window, and window down on command.? (FrostWhiteDC4)
Mine does that also. I have no idea on wiring though.
Old Jul 23, 2003 | 02:01 PM
Default Re: arm- roll up window, and window down on command.? (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">Mine does that also. I have no idea on wiring though.</TD></TR></TABLE>
arrrggggh.. hah find out!!! hah jk.. anyone?
Old Jul 23, 2003 | 03:04 PM
TrblPinoy1's Avatar
it's easy...just wire up the window up and down module as stated in the instructions...then there should be two wires left...one to trigger the up and one to trigger the down.....hook the up trigger to a armed output negative wire on the alarm...then hook up the down to a aux channel.....very simple...takes less than an hour too hook up four windows up/down...can also be hooked up to a sunroof or convertible top....
Old Jul 23, 2003 | 10:29 PM
Default Re: arm- roll up window, and window down on command.? (TrblPinoy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrblPinoy1 &raquo;</TD></TR><TR><TD CLASS="quote">it's easy...just wire up the window up and down module as stated in the instructions...then there should be two wires left...one to trigger the up and one to trigger the down.....hook the up trigger to a armed output negative wire on the alarm...then hook up the down to a aux channel.....very simple...takes less than an hour too hook up four windows up/down...can also be hooked up to a sunroof or convertible top....</TD></TR></TABLE>
thanks!
Old Jul 23, 2003 | 11:44 PM
philly-O's Avatar
get the modules made by dei, they are the best. 530t is 2 windows 2 ways including one touch, and the 529t which can be used for 2 windows 1 way or 1 window 2 ways (sunroof)
gsrturbo-ek
Audio / Security / Video
May 19, 2008 08:01 AM
accordinglyevil
Mar 11, 2008 05:44 AM
nex-gensjdmteg
Mar 28, 2005 06:42 PM
moleodonuts
Jul 26, 2004 02:42 PM
civicSlut
Apr 18, 2004 10:16 AM
