window roll up module
Old May 14, 2008 | 05:53 PM
gsrturbo-ek's Avatar
Default window roll up module
i recently installed my alarm and i have a separate module which you can hook up with your alarm and it will roll your windows up does anybody have any idea how to hook it up
the car is a 96 civic coupe ex
Old May 14, 2008 | 06:20 PM
B18C_EJ8's Avatar
Have you tried reading the instructions that came with the module?
Old May 15, 2008 | 04:04 PM
fcm's Avatar
fcm
Old Fart
Default Re: window roll up module (gsrturbo-ek)
Ditto the above.^^^
Also it would help if we knew the make ands model of the window module. 94
Old May 15, 2008 | 04:43 PM
boost'd_crx's Avatar
the easiest way to do it is to hook up all window wires from the driver door harness.
Old May 15, 2008 | 05:44 PM
Default Re: window roll up module (boost'd_crx)
yea its says just to tap into the wire from the switch wich makes the windows go up
the module is a bulldog 706
Old May 19, 2008 | 04:06 AM
datssoled's Avatar
Sorry I dont have an answer but a question related to yours...
Do all window roll up module work the same, despite the brand? Same with the trunk pop.
Old May 19, 2008 | 08:01 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost’d_crx &raquo;</TD></TR><TR><TD CLASS="quote">the easiest way to do it is to hook up all window wires from the driver door harness.</TD></TR></TABLE> You can't just " tap into the wire from the switch" the "up wires" must be cut, [red/blue for drivers side and blue/yellow for pass. side] and the Bulldog window modules wires connected to the cut leads.
Sorry I can't find a wire guide for the module, can you post it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by datssoled &raquo;</TD></TR><TR><TD CLASS="quote">Do all window roll up module work the same, despite the brand? Same with the trunk pop.</TD></TR></TABLE> In general yes all window modules work the same way.
All "trunk pop" solenoids are just about identical and use an electromagnetic solenoid as an actuator. 94
fujimi
Honda S2000
Sep 20, 2008 04:58 PM
Demonis
Honda Civic (2006 - 2015)
19
Sep 25, 2006 06:04 AM
Cashis Lee
Audio / Security / Video
12
Apr 8, 2005 09:02 AM
civicSlut
Apr 18, 2004 10:16 AM
weakGOODJunKieS.com
Jul 23, 2003 11:44 PM
