power window control.
Old Mar 10, 2008 | 07:46 AM
accordinglyevil's Avatar
Default power window control.
what i want to do is have a switch to roll up all four windows down at the same time and roll it back up at the same time. how would i go about doing this? i found the wire colors that control the up function and down function of all four windows already on the12volt.com website. i just need to know how to wire it up.
Old Mar 10, 2008 | 10:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: power window control. (accordinglyevil)
That would require 8 relays and a SPDT momentary switch, and a lot of wiring.
Each motor would need two relays wired to it, [ground at rest polarity reversing] and the switch wired to all the relays, 4 relays for up and the other 4 for down. 94
Old Mar 10, 2008 | 12:03 PM
thanks for the quick response, fcm. look like i'm over my head so i will either try to understand the concept if not then i'm not going to even try it.
thanks again tho.
Old Mar 11, 2008 | 05:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: (accordinglyevil)
You can install "window modules", two DEI 530T window modules will fully automate the windows, [auto up and down] all windows up when you arm an alarm, pairs of windows down using ans EXT output from alarm and window venting, [all windows up all the way and then down 1 inch] when you are an alarm.
The 8 relay thing is not that hard, all connections would be in the drivers door, [at wiring to drivers door window switches. 94
velocity101
Nov 1, 2008 10:45 AM
mooseheads36
Audio / Security / Video
Jan 27, 2007 02:24 PM
poison
30
Mar 14, 2003 02:44 PM
vtec_addict
Nov 19, 2002 11:30 AM
Blockhead G
Aug 14, 2002 06:30 AM
