Amplifier install
Old Sep 2, 2004 | 11:17 AM
macaronak's Avatar
Default Amplifier install
I am trying to put in an amplifier in my 98 prelude to the factory headunit. Does anyone know where I can hook up the remote wire? I tried the yellow and white wire on the wiring harness as circuit city told me it was the power antenna wire and didnt work. Any ideas??
Old Sep 2, 2004 | 11:51 AM
milton's Avatar
Default Re: Amplifier install (macaronak)
do ui have a harness on the deck?
Old Sep 2, 2004 | 12:20 PM
PM-Performance's Avatar
Default Re: Amplifier install (milton)
froom the top of my head you are going to need a line out inverter since you wont have pre amp signal.
if i remember correctly, the line out inverters will have the remote turnon spot to go from the amp to that, and when that senses signal from the speaker level inputs it will turn on.
its been a while since ive done one of them .
Old Sep 2, 2004 | 03:10 PM
Goatsterrman's Avatar
Default Re: Amplifier install (itr206)
Behind the radio there will be one wire that turns on and off with the Key, that is your accessory wire, that is the wire you are looking for, use a T-tap and tap into it, run the remote wire from that. Use a multimeter to test for 12 volts with the key.
Old Sep 2, 2004 | 05:13 PM
shibby's Avatar
Default Re: Amplifier install (Goatsterrman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goatsterrman &raquo;</TD></TR><TR><TD CLASS="quote">Behind the radio there will be one wire that turns on and off with the Key, that is your accessory wire, that is the wire you are looking for, use a T-tap and tap into it, run the remote wire from that. Use a multimeter to test for 12 volts with the key.</TD></TR></TABLE>
and make sure you test this wire when the car is off also, because you dont want a constant 12 volts or it will drain your battery.
Old Sep 3, 2004 | 07:43 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macaronak &raquo;</TD></TR><TR><TD CLASS="quote">I am trying to put in an amplifier in my 98 prelude to the factory headunit. Does anyone know where I can hook up the remote wire? I tried the yellow and white wire on the wiring harness as circuit city told me it was the power antenna wire and didnt work. Any ideas?? </TD></TR></TABLE> All Hondas have a acc., and a ign.2 term. on fuse box, use one of them. 94
Jordan8742
Audio / Security / Video
Mar 25, 2015 09:19 AM
bopbop93030
13
May 5, 2009 11:08 AM
kcivicboi
Feb 23, 2006 11:26 AM
boostincoupe
Oct 6, 2005 05:19 PM
SIMATIC
Jul 2, 2003 07:41 AM
