NEED EP3 Stereo help!
Old Sep 1, 2004 | 08:48 PM
sideout2002's Avatar
Default NEED EP3 Stereo help!
Just installed an aftermarket stereo using wireharness. My keyless entry no longer works! Is there a different wire harness for the 02 civic Si that needs to be used with keyless entry?
Old Sep 2, 2004 | 03:21 PM
Goatsterrman's Avatar
Default Re: NEED EP3 Stereo help! (sideout2002)
I'm not sure, but I know on the EK si's there was a wire you needed to jump behind the radio, on the two green plugs, Not sure if this is still true for the EP3's though.
If you installed a radio and didn't jump the wires, then Keyless Entry would no longer work.
Old Sep 3, 2004 | 07:56 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sideout2002 &raquo;</TD></TR><TR><TD CLASS="quote">Just installed an aftermarket stereo using wireharness. My keyless entry no longer works! Is there a different wire harness for the 02 civic Si that needs to be used with keyless entry?</TD></TR></TABLE> You may need a "T" harness and have to leave the oem HU inbehind the dash I think the keyless uses the rf section of the oem HU , or you can just add an alarm and wire the doorlocks to it. 94
erickcanales93
Honda Civic (2006 - 2015)
Oct 29, 2013 08:34 PM
xtegb16x
Audio / Security / Video
13
Jun 14, 2006 05:40 PM
SumOne
May 26, 2006 04:06 AM
redman223
Jul 10, 2004 07:34 AM
ilario
Mar 31, 2003 12:40 AM
