REMOTE WIRE
Old Feb 20, 2006 | 04:43 PM
kcivicboi's Avatar
Default REMOTE WIRE
Hi, i got a 2001 civic. got a newer alpine head unit. i was wondering which wire is the remote wire, thanks.
Old Feb 20, 2006 | 05:01 PM
kcivicboi's Avatar
Default Re: REMOTE WIRE (kcivicboi)
also, which is the best location to ground the amp too???
Old Feb 20, 2006 | 07:09 PM
suspendedHatch's Avatar
You're talking about the blue wire coming off the deck? That wire would be extended and run to your amp remote turn on input if you had amps. If you don't, then insulate the tip.
Ground the amp to the bare metal chassis near the amp. I prefer factory bolts, and I take the paint off with a special bit I have.
Old Feb 20, 2006 | 07:14 PM
FULL throTTLe's Avatar
if u trying to run an amp, and u want to know which wire to run into the deck, its the blue wire with white stripe, thats usually the one on pioneers and kenwood deck.
Old Feb 23, 2006 | 05:47 AM
VisualAutoMotoring's Avatar
Default Re: (FULL throTTLe)
If your looking for the factory remote wire, its probably an accesory wire. But to save time and hassle, get yourself a plug n play factory wire harness plug. Any local stereo shop sells them and saves you from hacking away at your factory harness and usually makes the install pretty clean
Old Feb 23, 2006 | 06:02 AM
MLD211's Avatar
Default Re: (Hybrid-Performance.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com &raquo;</TD></TR><TR><TD CLASS="quote"> But to save time and hassle, get yourself a plug n play factory wire harness plug.</TD></TR></TABLE>
I think in this case using a harness and reverse harness would be a lot of work when all you need to tap is one wire for the remote. Also then you have to try to fit an additional 2 plugs all the wires and connectors as well as a line out converter behind the radio. I would probably just tap the wires.
Old Feb 23, 2006 | 11:04 AM
fcm's Avatar
fcm
Old Fart
Default Re: (MLD211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLD211 &raquo;</TD></TR><TR><TD CLASS="quote">
I think in this case using a harness and reverse harness would be a lot of work when all you need to tap is one wire for the remote. Also then you have to try to fit an additional 2 plugs all the wires and connectors as well as a line out converter behind the radio. I would probably just tap the wires.</TD></TR></TABLE>? you would only need the oem radio harness plug adapter, [into car adapter] Metra 20-1721, connect it color for color with the Alpine harness, then use the blue/white, as FULL throTTLe mentioned, the solid blue on an Alpine HU is power ant. control and has no power when CD is playing. 94
Old Feb 23, 2006 | 11:08 AM
phateless's Avatar
DEF. use the harness adapter. for one thing, you can do all your wiring connections at your desk inside, instead of hunched over inside your car. then just plug and play.
Old Feb 23, 2006 | 11:18 AM
MLD211's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">? you would only need the oem radio harness plug adapter, [into car adapter] Metra 20-1721, connect it color for color with the Alpine harness, then use the blue/white, as FULL throTTLe mentioned, the solid blue on an Alpine HU is power ant. control and has no power when CD is playing. 94</TD></TR></TABLE>
I was responding to this, meaning if he was running a factory radio. With the after market there would be no need for the factory turn on. obviously. I think I just mis read the post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com &raquo;</TD></TR><TR><TD CLASS="quote">If your looking for the factory remote wire</TD></TR></TABLE>
Old Feb 23, 2006 | 11:26 AM
phateless's Avatar
i think i get it. my 9807 has 2 remote wires. 1 for an amp, and one for the power antenna. is that what you meant?
bopbop93030
Audio / Security / Video
13
May 5, 2009 11:08 AM
sasser43
Jan 4, 2007 05:13 PM
boostincoupe
Oct 6, 2005 05:19 PM
ChaosUnbound
Feb 24, 2004 04:20 PM
another_crx
Dec 28, 2003 06:39 AM
