amperage rating??
Old Jul 16, 2005 | 09:16 AM
weak_tec's Avatar
Default amperage rating??
what amperage rating on a rocker switch are you all using for fuel cuttoff??
Old Jul 16, 2005 | 09:53 AM
fcm's Avatar
fcm
Old Fart
Default Re: amperage rating?? (spoon_meeH)
If you install the switch on the power line to the fuel pump or the power line into the fuel pump relay, just match it to the same size as the fuel pump fuse in your fuse box, if on the other hand you install the switch into the relay control line from the ECU, all you need is a 1/2 amp switch, [as a relay only needs under 250 mA to "trigger"] 94
Old Jul 16, 2005 | 10:46 AM
nsxxtreme's Avatar
Default Re: amperage rating?? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">if on the other hand you install the switch into the relay control line from the ECU, all you need is a 1/2 amp switch, [as a relay only needs under 250 mA to "trigger"] 94</TD></TR></TABLE>
Killspeed93
Audio / Security / Video
Jan 30, 2011 04:42 PM
Mr.Death
Jul 21, 2008 07:11 PM
raphael
May 2, 2006 03:07 PM
PearlWhiteAccord
Feb 23, 2006 11:36 AM
92integraVTECgsr
Oct 10, 2005 09:14 PM
