what should i use
Old May 1, 2006 | 06:53 PM
raphael's Avatar
Default what should i use
i want to know how to can i wire up a fuel pump kill switch? i work at a auto parts store so i have good access to switches and car wire
Old May 1, 2006 | 07:16 PM
B18C_EJ8's Avatar
Did you even bother to read the 8 page thread at the top of this forum on the subject?
Old May 2, 2006 | 12:22 PM
raphael's Avatar
i did but for some reason in doesnt open when i click on it.i wouldnt have asked if it was rite on top of everything
Old May 2, 2006 | 03:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (raphael)
There are a few ways to do it, installing a switch on a relay control line would only require a low current switch, [1A max], installing a switch on a main power line, will require a 15A-20A switch, or a relay.
IMO the best way is to install a switch on the fuel pump relays control lead, [low current ground] it runs from the ECM/ECU to the fuel pump relays coil in the PGM-Main Relay, [the PGM-Main Relay has 2 relays inside, one is the fuel pump power and the other is the fuel injectors power] the color of the wire varies from model to model and year to year. 94
Killspeed93
Audio / Security / Video
Jan 30, 2011 04:42 PM
g2tegsown
13
Aug 21, 2008 10:30 AM
Mr.Death
Jul 21, 2008 07:11 PM
Mikes2000civicsi
Feb 2, 2008 03:59 PM
5lugSlug
Sep 18, 2005 12:25 PM
