Killswitch
Old Jan 22, 2011 | 11:42 PM
Killspeed93's Avatar
Icon2 Killswitch
i want to get a kill switch for my tegg but i dont know where to go where can i go and buy one and how much do they tend to cost
Old Jan 23, 2011 | 08:13 AM
fcm's Avatar
fcm
Old Fart
Default Re: Killswitch
$2.99 at any electronics store, Radio Shack...http://acuraautomotiveparts.org/acur...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
The type and size of switch you use will depend on what you want to "kill". 94
Old Jan 23, 2011 | 07:02 PM
well what do you recomend to wire it? what would be the best way to do it ?
Old Jan 24, 2011 | 05:42 AM
fcm's Avatar
fcm
Old Fart
A small 1A switch can be used to interrupt the ground for the PGM-FI Main Relay, ["killing" the injector relay and the fuel pump relay, or the ECU/ECM control lead for the fuel pump relay, ["killing" the fuel pump].
A small 1A switch can also be used to control a relay and the relay can be put on any lead. [starter, ign., fuel pump power lead].
There is a lot of info on "kill switches" here, you need to search a little. 94
Old Jan 29, 2011 | 05:54 AM
guru350's Avatar
can you put a killswitch on your clutch and if yes how
Old Jan 29, 2011 | 09:56 AM
fcm's Avatar
fcm
Old Fart
You would not put it on your clutch, you could put it on the CIS, [clutch interlock switch], installing a switch on either of the two leads at the CIF would prevent starter relay closing, however this is easily bypassed with a bypass jump, as "layer" it is effective as it is one more thing to slow a car thief down, I have 3 "kills" on my 94 Integra, only one of them controlled by the Alpine alarm, one is passive arming w/ stealth switch, [latching relay] the 3rd is a hidden switch, [on/off] 94
Old Jan 30, 2011 | 04:42 PM
djkurious's Avatar
Hope these help:
http://causeforalarm.thecarthing.com/version6/
http://causeforalarm.thecarthing.com...on7/index.html
jdmjin
Audio / Security / Video
10
Sep 15, 2008 04:47 AM
g2tegsown
13
Aug 21, 2008 10:30 AM
raphael
May 2, 2006 03:07 PM
5lugSlug
Sep 18, 2005 12:25 PM
VTECorona
Aug 27, 2003 05:50 PM
