Igniton Kill Switch
Old Oct 9, 2005 | 10:14 AM
92integraVTECgsr's Avatar
Default Igniton Kill Switch
I want to instal a kill switch to my ingnition. Do i need a fuse or relay?
Can I i just cut the wire, install a switch and fuse inbetween the 2 wires and have it work?
Old Oct 9, 2005 | 12:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: Igniton Kill Switch (92integraVTECgsr)
You will need a relay or a very big switch, a relay and a small switch to control the relay is best, there are a number of ways to do Ign./starter kills most will work for both, you will find all sorts of things to do with relays here http://sonolithics.com/files/bosch.pdf hope this helps, feel free to IM me if you need more help. 94
Old Oct 9, 2005 | 01:02 PM
ok.. doing a fuel pump kill switch.
i got a 15amp switch. a inline fuse (going to use a 3 amp??).
should this be ok??
and does it go like this: swtich, fuse, fuel pump. or fuse, switch, fuel pump.
Old Oct 10, 2005 | 09:14 PM
db8xc1x39
Guest
Posts: n/a
just do it on the ignition, no car will run without ignition and its safer and more secure than starter kill..
92integraVTECgsr
Audio / Security / Video
Oct 10, 2005 07:24 PM
GR_DC2
May 27, 2004 10:51 PM
TurboTurtleGSR
Jan 17, 2003 09:04 PM
Ham'ed Hatch
Jul 12, 2002 11:03 AM
ionic_slim
May 29, 2002 08:10 PM
