Alarm LED Location?
Alarm LED Location?
I have a 2002 accord and I am installing the factory security system. The owner's manual shows the LED located on the drivers door, by the lock ****, up by the window. The installation manual for the security system says to put it on the top of the steering column. Is there a "best" location? I assume if I move it from where it will reach, that the LED wires can be extended? I know this is a pretty simple question....just want to make sure. Thanks...
Re: Alarm LED Location? (Golferdude1977)
yeah you could extended them. just soilder on some longer wires. also i would put it on the sterring c. or get a led light strip off ebay and mount it on the dash.
My LED for my Viper 791XV is mounted upside down in the gauge bezel, centered between the two screws. That LED is bright as hell, and it lights up the whole car at night.
I say - don't get an LED......just let it look how its supposed to......
but get a proximity sensor .......with the voice module.......hmm.......
Re: (TheKingPin)
on DEI LED's you can take off the red plastic cover and you left with a tiny clear led bulb. The led still blinks red. Drill a small hole and push the led in from behind. Then use hot glue to hold it there. Cleanest led install and when its off you barley notice it.
I agree with MLD211. It doesn't matter where you mount it, it always functions the same. It's all personal preference. I have mine mounted in the A pillar towards the top pointed towards the center of my dash. Looks cool at night or when there's water on my windshield. Good luck.
Nate
Nate
I would recomend mounting it anywhere that is visible from almost anywhere outside of the car . As well as in a spot that can be replaced ( i.e a pop out panel ) . This in case you want to take it out , you wont have a hole in some panel that is millions to replace
Old Fart
Re: (PlusOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlusOne »</TD></TR><TR><TD CLASS="quote">I would recomend mounting it anywhere that is visible from almost anywhere outside of the car . As well as in a spot that can be replaced ( i.e a pop out panel ) . This in case you want to take it out , you wont have a hole in some panel that is millions to replace
</TD></TR></TABLE> Ditto that, Find the cheapest piece of plastic to replace, [if you had to] and mount it to that, a dummy plug for a switch that you don't have works real good, next best thing is the top piece of the steering column trim, it's highly visible and its a cheap piece of plastic to replace, [relative to other dash or console trim] 94
justint
04-08-2006 09:58 PM
deoexmacchina
Audio / Security / Video
10-17-2005 05:28 PM
Undepelo
08-19-2002 09:09 PM
