Alarm is a bit inconsistent.
Old Aug 23, 2007 | 09:31 AM
hust1er's Avatar
Default Alarm is a bit inconsistent.
Car: 2000 civic si
I juss installed a alarm in my car but the problem is its pretty inconsistent with working...
I know interms of the door triggers, locks, 12v constant, and acc wires they are wired correctly. How do i know this? because when the alarm actually works... everything works fine.
It seems to <U>randomly</U> cut in and out of working. At first i thought it was my power connections because like 90% of the time if i turnd the ignition the alarm would start working (the keyless entry worked) but the alarm brain has a indicator that shows it is recieving power and operational ignition turned or off.
...so now im thinking mayb its my ground. Its not directly on the chassis but i picked a bolt connected to the metal frame/brackets under the dash. It seemed like a good ground to me...but im no pro.
so my question is...is there a way to test if that ground is good or not....or am i better off just looking for another spot. or is it juss some *** alarm that is busted...(got it in china)
Old Aug 23, 2007 | 09:56 AM
B18C_EJ8's Avatar
Default Re: Alarm is a bit inconsistent. (hust1er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hust1er &raquo;</TD></TR><TR><TD CLASS="quote"> Its not directly on the chassis but i picked a bolt connected to the metal frame/brackets under the dash. It seemed like a good ground to me...but im no pro.</TD></TR></TABLE>
Aren't you the one who bought the $39.99 alarm on eBay?
Anyways... Your ground is inadequate. Secondary grounds are not acceptable.
Scrape some paint off of the kick panel and ground there.
Old Aug 23, 2007 | 09:59 AM
suspendedHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hust1er &raquo;</TD></TR><TR><TD CLASS="quote">I know interms of the door triggers, locks, 12v constant, and acc wires they are wired correctly. How do i know this? because when the alarm actually works... everything works fine.
WRONG! Why do people always say this?! I KNOW it's hooked up right, but it doesn't work. If it was hooked up right, it would work. Period. Well, unless it's a crappy brand of alarm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
(got it in china)
Oh, you got the alarm in China? Well that could be your problem right there. But back to what I was saying... if it was a reputable alarm, and it was hooked up correctly, then it would work. Very rarely will you encounter a defective alarm from a reputable company. In a sticky linked in the FAQ section, I warn against using any imported alarms. Currently all the good alarms are made in the US and Canada.
Did you solder all connections? Did you verify all connections with a voltmeter? Did you use relays for all inputs/outputs that were listed in mA?
That's not right. You KNOW it's connected right when you've verified everything with a voltmeter, double checked it, and then confirmed it by some other method.
Old Aug 23, 2007 | 10:05 AM
hust1er's Avatar
Default Re: Alarm is a bit inconsistent. (B18C_EJ8)
no thats wasnt me
Old Aug 23, 2007 | 10:10 AM
hust1er's Avatar
Default Re: Alarm is a bit inconsistent. (suspendedHatch)
ill redo my grounds
...n yes i soldered my connections and checked them with the voltmeter.
i didnt use any relays for the listed connections, but id like to know if i should.
how can i tell if a specific connections are listed mA?
Old Aug 23, 2007 | 01:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hust1er &raquo;</TD></TR><TR><TD CLASS="quote">how can i tell if a specific connections are listed mA?</TD></TR></TABLE>
Because the poorly translated instructions will say "250mA" or "500mA" on that particular wire in the diagram.
Old Aug 26, 2007 | 11:33 AM
hust1er's Avatar
iight...well everythings workin fine now.
Ive read the faq:
"Glass breakage
Use this sensor or a motion sensor, but not both."
now my next question is which sensor is more recommended. Seein that the glass breakage sensor is cheaper i was leanin toward that...but i would get the motion/prox sensor if it was better.
Old Aug 30, 2007 | 09:46 AM
hust1er's Avatar
i juss got a tilt sensor...still waitin on opinions on the other sensor
Azavala
Audio / Security / Video
11
Jul 16, 2016 04:08 PM
Nameless Warrior
17
Feb 24, 2007 08:42 AM
PariahBoardshop
Aug 9, 2004 03:04 PM
eg686
10
Mar 25, 2003 02:26 PM
Audipwr1
Nov 23, 2001 06:35 PM
