alarm wont work
Old Jul 8, 2016 | 09:10 PM
Azavala's Avatar
Default alarm wont work
So i have a 1996 honda civic ex and recently bought a viper 3105 alarm system and got it all finished up or so I thought and I went to test it and the alarm armed and then i opened drivers side door and alarm went off but was very quiet and then the alarm wouldn't dissarm and i tried to start the car and it did start up so what did i do wrong? I reazlied after that i can run all the wires in dkp so thats why mine are all over the place. much appreciate thank you.
Old Jul 9, 2016 | 01:00 PM
fcm's Avatar
fcm
Old Fart
Default Re: alarm wont work
Check your ground for the alarm.
Where did you ground the alarm?
A weak siren and no disarm along with start ability when alarming points to a grounding problem.94
Old Jul 9, 2016 | 04:05 PM
Azavala's Avatar
I ground to a screw in drivers door just for the time being because I wanted to test the alarm.
Old Jul 9, 2016 | 04:06 PM
Azavala's Avatar
I got the car to dissarm and arm now but the siren sound very dim and i wired the yellow wire to same spot as ignition for the killswitch relay Am i able to do that? thank you
Old Jul 9, 2016 | 07:52 PM
Azavala's Avatar
status update. so i red into another thread and i saw that the yellow wire was suppose to run to ingition accesory and I read that the white black wire running to fix box from iginition was an accesory so i tapped into that and went to start the car and whenever clutch was pressed in the starter would try starting even when it was already on so i removed that wire and still was doing it then disconnted the green and black wires and it stopped, so obviously somehow the start was getting 12v whenever clutch was pressed in even while running
Old Jul 10, 2016 | 10:14 AM
fcm's Avatar
fcm
Old Fart
You have miss-wired the alarm.
Alarms red lead, [power] connects to the white at the ign. switch
Alarms yellow lead, [switched power] connects to the black/yellow at ign. switch.
The starter cut relay is installed on the black/white lead at the ign. switch, [cut black/white lead and install relay to the two cut leads, [green and black leads from relay connect to cut black/white starter lead] orange controls the start cut relay..
It is important that the yellow lead from the relay is connected to a "true ign." lead, [hot in run and start] like the black/yellow, [just like the alarms ign. lead.
The black ground lead needs to be grounded to a good chassis ground point, use the same ground point to ground the siren, grounding "in the door" is not a good ground. 94
Old Jul 10, 2016 | 12:38 PM
Azavala's Avatar
sweet man i appreicate the help thanks again
Old Jul 10, 2016 | 01:30 PM
Azavala's Avatar
so all i need to fix is my constant power to white wire from ignition harness?
Old Jul 11, 2016 | 05:53 AM
MotoCARR's Avatar
If you ran it all the way to your battery, it's fine it can stay. It's just that running it to the white wire in your ignition harness would have been easier.
Like FCM said, change your ground to either the same point as the siren, or a good solid BARE METAL point then retest.
Old Jul 15, 2016 | 05:07 PM
Azavala's Avatar
I have done that and kill switch still doesn't work
Old Jul 16, 2016 | 07:25 AM
fcm's Avatar
fcm
Old Fart
Still same problem?
Arms and disarms but will not trip and siren "weak"???
Where did you get this alarm? 94
Old Jul 16, 2016 | 04:08 PM
Azavala's Avatar
Still same problem?
I just was busy with work so hadn't got around till today. Got it working thanks again man. Really appreciated it
JDM_Ej
Audio / Security / Video
20
May 4, 2014 06:27 PM
1BADEGDC2
11
Feb 23, 2009 01:33 PM
Ej1_coupe
Mar 27, 2005 03:58 PM
V-Grip! Teknic73
Apr 28, 2003 04:35 AM
