Tippyman's Project Thread
Old Jan 6, 2008 | 05:09 PM
  #1851
misha's Avatar
Default Re: (Tippyman)
  #1852
gee510's Avatar
Default Re: Tippyman's Project Thread (migizzel)
good start it looks really good
Old Jan 9, 2008 | 06:02 PM
  #1853
Tippyman's Avatar
Default Re: Tippyman's Project Thread (gee510)
Wideband came in today.
The next purchase I make will be $575 in OEM parts. Then it's down to business.
Old Jan 22, 2008 | 05:52 PM
  #1854
Tippyman's Avatar
Default Re: Tippyman's Project Thread (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
The next purchase I make will be $575 in OEM parts. </TD></TR></TABLE>
Scratch that.
FJT here on Honda-tech recently opened up his own online store! It's pretty much a one-stop shop for 3-400 hp single cams! AND CHEAP AS HELL! http://fjdistributors.com/index.php
I just bought a complete gasket kit and a set of ACL bearings for $142! ACL bearings for $63?! Madness...
So this engine may be getting built alot faster than I thought.
Old Jan 22, 2008 | 06:43 PM
  #1855
kirbyman's Avatar
Old Jan 22, 2008 | 09:21 PM
  #1856
90sedan's Avatar
Scratch that.
So this engine may be getting built alot faster than I thought. </TD></TR></TABLE>
woot woot!
Old Jan 23, 2008 | 05:21 AM
  #1857
fjt's Avatar
fjt
Wow thanks!!
And now we are soon to release our Custom forged rods designed specifically to run the Vitara pistons..
http://www.turbod16.com/viewtopic.php?f=13&t=41237
We are here to try and help the D series comunity as much as we can.
Old Jan 23, 2008 | 07:45 AM
  #1858
teamlegacy's Avatar
Default Re: (fjt)
Damn, I wish those options were available for my motorset. I'd plaster your name all over my car for prices like that!
Old Jan 23, 2008 | 09:29 AM
  #1859
Tippyman's Avatar
Default Re: (teamlegacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy &raquo;</TD></TR><TR><TD CLASS="quote">Damn, I wish those options were available for my motorset. I'd plaster your name all over my car for prices like that!</TD></TR></TABLE>
Yeah, crazy ****! Too bad all single cams are not created equal.
Old Jan 23, 2008 | 10:34 AM
  #1860
teamlegacy's Avatar
Yea, because then I'd be DOWNgrading.
Old Jan 23, 2008 | 02:22 PM
  #1861
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy &raquo;</TD></TR><TR><TD CLASS="quote">Yea, because then I'd be DOWNgrading. </TD></TR></TABLE>
Nothing wrong with making high hp outta motors no one wants. We are kinda the same in that aspect.
Old Feb 17, 2008 | 04:22 PM
  #1862
Tippyman's Avatar
Well, I haven't posted in here in a long while, so I guess I'll update the status.
I got a AFX wideband/sensor. It's all been heat shrunk in Raychem Should be installed soon.
No real progress actually been done to the car, unfortunately. I've just been preparing stuff. My next goal:
BUILD THE DAMN ENGINE!!!
In order to do that I still need:
-$200 in parts
-get it machined
-Innovative mounts from Autoworks
That's it! Next month it should be good to go. I'm building the bottom end, getting it all assembled and ready to go, then pulling the head and OEM oil cooler off of my ZC and using it on the built block. Yeah, I'll be running 7.9:1 compression all motor for a while.
BTW: The valve cover for the new engine will be hot.
Old Feb 17, 2008 | 04:24 PM
  #1863
TallKyle's Avatar
i miss tippyman
Old Feb 17, 2008 | 04:25 PM
  #1864
redzcstandardhatch's Avatar
something different
build it!
Old Feb 18, 2008 | 07:56 AM
  #1865
Creator's Avatar
June 7th make or break!...ehh you got plenty of time. We still want to see progress. I'm tryin to finish an already LS now going Vtec swap myself. I can't handle the pressure of a build thread though.
Actually, I don't have access to a PC at the house anymore so I couldn't pull it off.
Old Feb 18, 2008 | 11:43 AM
  #1866
Tippyman's Avatar
Default Re: (Creator)
I don't know if it will be boosted by the seventh, but I hope to have the engine/trans done by then in addition to all the other **** I want done to the car in preparation for some boosted love.
Old Feb 24, 2008 | 07:28 PM
  #1867
Tippyman's Avatar
I notched the block tonight for rod clearance. I think I may have notched it a little too much, but better to much than too little I guess.
She is going to the machine shop tomorrow and getting picked up Wednesday!
Old Feb 24, 2008 | 09:19 PM
  #1868
eda6's Avatar
I'm taking a break from learn as you go, trial and error, diy transmission rebuilding.....3 input shaft bearings and 2 ball bearings for the mainshaft killed, warped an oil plate, a ring gear swap, 4th gear grind, bad diff bearings, stripped threads, spring washers installed incorrectly, another stripped thread after the tranny is installed in the car. resolved bearing issues and 10 miles later i'm locked out of 3rd gear becuase the synchro spring broke and wedged between the sleeve and ring
tippy what are your plans to freshen up the transmission??
Old Feb 24, 2008 | 11:19 PM
  #1869
tunerkid7's Avatar
Default Re: Tippyman's Project Thread (eda6)
very cool man lotsa time and effort for you
Old Feb 24, 2008 | 11:31 PM
  #1870
90sedan's Avatar
Default Re: Tippyman's Project Thread (tunerkid7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I notched the block tonight for rod clearance. I think I may have notched it a little too much, but better to much than too little I guess.
She is going to the machine shop tomorrow and getting picked up Wednesday! </TD></TR></TABLE>
About time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">I'm taking a break from learn as you go, trial and error, diy transmission rebuilding.....3 input shaft bearings and 2 ball bearings for the mainshaft killed, warped an oil plate, a ring gear swap, 4th gear grind, bad diff bearings, stripped threads, spring washers installed incorrectly, another stripped thread after the tranny is installed in the car. resolved bearing issues and 10 miles later i'm locked out of 3rd gear becuase the synchro spring broke and wedged between the sleeve and ring
A little instruction would have gone a long way!
However, sometimes the only way to learn is by doing it the hard-way.
Old Feb 26, 2008 | 04:12 PM
  #1871
Tippyman's Avatar
tippy what are your plans to freshen up the transmission??</TD></TR></TABLE>
New bearings/synchro's and an OBX LSD.
I'm debating whether or not to send the gears to "RacerStev" to have them heat treated.
Well, got the block & flywheel back from the machine shop today. Took it to Magnum Machine in Chesapeake, VA. It was right next to my school and came with good recommendations. They actually finished it in ONE DAY.
Had the block hot-tanked, bored/honed, and decked.
I decided to go with .0035" of piston to wall clearance for the ole' Vitara's. The guy at the shop got a kick out of the fact that I was using Suzuki pistons in a Honda. When I pulled up to the shop he opened up the garage door so I could back my car in to unload the block. I just parked in the parking lot, and picked up the block with one arm and handed it to him. He got a kick out of that too. Damn Hondas...
So I guess I'll start putting some **** together tomorrow!
Old Feb 26, 2008 | 04:22 PM
  #1872
JKGONZALEZ3's Avatar
sounds good tippy. dont forget to take pics.
if you dont mind me asking how much was the machine shop price for the bore/honed??
i probably souldent compare prices from ca to va but eh. theres a machine shop on my block. who woulda known there was one there if they havent had told me.
Old Feb 26, 2008 | 04:40 PM
  #1873
Tippyman's Avatar
Default Re: Tippyman's Project Thread (JKGONZALEZ3)
It was $210. Not bad, really...
Old Feb 26, 2008 | 05:07 PM
  #1874
well, either my shop sucks or they really need customers cause they charge $20 to bore/hone each cylinder
Old Feb 26, 2008 | 05:27 PM
  #1875
Tippyman's Avatar
Default Re: (JKGONZALEZ3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKGONZALEZ3 &raquo;</TD></TR><TR><TD CLASS="quote">well, either my shop sucks or they really need customers cause they charge $20 to bore/hone each cylinder</TD></TR></TABLE>
Well, that's $80. Then I had it decked. That was $40. The hot-tank was like $30. Then they did the flywheel too. That was $40 I believe.
So that's $190. Sounds about right.
I trusted my shop because they actually asked me where they wanted me to measure the piston skirt for clearance, what material the rings were made out of so they could hone it correctly, etc.
