Tippyman's Project Thread
Old Dec 21, 2006 | 06:57 PM
  #901
Got_soy's Avatar
Default Re: (Turbogixxer)
you have to jump a conector with odb0? thats new to me
Old Dec 21, 2006 | 06:58 PM
  #902
UltimX's Avatar
Default Re: (Got_soy)
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">you have to jump a conector with odb0? thats new to me</TD></TR></TABLE>
Old Dec 21, 2006 | 07:00 PM
  #903
janz3n's Avatar
Default Re: (UltimX)
well then.. iv got something to do tomorrow .lol
Old Dec 21, 2006 | 07:01 PM
  #904
Turbogixxer's Avatar
Honda (for OBD0) calls the connector the "ignition adjustment" connector.
Old Dec 21, 2006 | 07:48 PM
  #905
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Your computer controls the timing too. You have mechanical timing (moving your distributor) and electrical timing (what your ECU adds). When you jumper the service connector, it locks the ECU timing so you can adjust the mechanical timing to spec. IF you do not jump it, the ECU will try to "correct" the timing with you move the distributor. </TD></TR></TABLE>
Correct.
Old Dec 22, 2006 | 07:21 AM
  #906
teamlegacy's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Just getting all the plans down on paper. I'm getting excited about next summer though. </TD></TR></TABLE>
Oh yea? You're still gay.
Old Dec 22, 2006 | 07:24 AM
  #907
janz3n's Avatar
Default Re: (teamlegacy)
so i adjusted my timing without jumpnig the connector. will the ecu correct the timing back to what it was before i moved it? or will the timing be changed a bit? cuz i was running rich and i moved it and it doesnt run as rich anymore.
Old Dec 22, 2006 | 07:29 AM
  #908
Default Re: (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">so i adjusted my timing without jumpnig the connector. will the ecu correct the timing back to what it was before i moved it? or will the timing be changed a bit? cuz i was running rich and i moved it and it doesnt run as rich anymore.</TD></TR></TABLE>
If you move it at any time, it will add or subtract timing (depending on what way you move it). You cant check it with a light to see what timing you are running.
Old Dec 22, 2006 | 08:14 AM
  #909
Autoworks's Avatar
It's nice!</TD></TR></TABLE>
Boost FTW
Old Dec 22, 2006 | 08:45 AM
  #910
janz3n's Avatar
If you move it at any time, it will add or subtract timing (depending on what way you move it). You cant check it with a light to see what timing you are running.</TD></TR></TABLE>
ya but will the computer move the timing all the way back to where it was before i changed it?? if i didnt jump the connector? i dont have a timing light.
Old Dec 22, 2006 | 08:57 AM
  #911
ya but will the computer move the timing all the way back to where it was before i changed it?? if i didnt jump the connector? i dont have a timing light.</TD></TR></TABLE>
No, if you move the distributor, it will add mechinical timing. So, if you add 2*, it will add 2* for the whole ECU Map.
If you try to move it and check it without jumping the connector, the ECU will try to put it back to the timing it wants. When you jump the connector, it locks the timing so the ecu does not change it. Stock maps move the timing around at idle.
Old Dec 22, 2006 | 10:45 AM
  #912
ef-hatchcrap's Avatar
couldnt you just get an adjustable cam gear? Or just take the timing belt off and adjust the timing on the by turning the cam gear and putting the head back on? I may be wrong so tell me if I am.
Old Dec 22, 2006 | 11:00 AM
  #913
Tippyman's Avatar
Default Re: (ef-hatchcrap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap &raquo;</TD></TR><TR><TD CLASS="quote">couldnt you just get an adjustable cam gear? Or just take the timing belt off and adjust the timing on the by turning the cam gear and putting the head back on? I may be wrong so tell me if I am. </TD></TR></TABLE>
I could, but to tell you the truth, I'm not all that worried.
I am going to tone it down to a 50 shot, this setup will be more than adequate for that. If I run 13's, awesome, if not, no biggie. I'll run this setup til I have the next one built. It should be fun.
So, it'll be fun spraying for a while, but I'm really not too into it anymore now that I'm gonna start building a motor for boost. 300 whp should be ALOT more fun, lol.
Old Dec 22, 2006 | 11:02 AM
  #914
Got_soy's Avatar
you want to buy my hf mani?
Old Dec 22, 2006 | 11:07 AM
  #915
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">you want to buy my hf mani? </TD></TR></TABLE>
Lol, I think to get 300 hp outta that I'll have to run more boost than I want to.
I am probably going to get a "mini-pro" mani from Autoworks.
Old Dec 22, 2006 | 11:15 AM
  #916
alright just a suggetion. How much do you want for that hf mani?
Old Dec 22, 2006 | 11:38 AM
  #917
teamlegacy's Avatar
Tim, I've got some black-top DSM injectors for you too.
Old Dec 22, 2006 | 11:41 AM
  #918
Autoworks's Avatar
I am probably going to get a "mini-pro" mani from Autoworks.</TD></TR></TABLE>
hellz yeah
If you need injectors or anything else let me know (I've got a set of blut tog 450s here too)
Old Dec 22, 2006 | 06:39 PM
  #919
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy &raquo;</TD></TR><TR><TD CLASS="quote">Tim, I've got some black-top DSM injectors for you too.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
hellz yeah
If you need injectors or anything else let me know (I've got a set of blut tog 450s here too)</TD></TR></TABLE>
I need at least 550's. 450 will be maxed out. 550's are even really not good past 350ish.
Old Dec 22, 2006 | 06:44 PM
  #920
Got_soy's Avatar
you trying for 400?
Old Dec 22, 2006 | 06:50 PM
  #921
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">you trying for 400?</TD></TR></TABLE>
Shooting for a solid 300 to the wheels on a fairly conservative tune.
Old Dec 23, 2006 | 05:01 AM
  #922
teamlegacy's Avatar
You'll be fine with 450's.
Old Dec 23, 2006 | 07:47 AM
  #923
1990si's Avatar
at least get the nitrous seup going. dont quit and start another project.
Old Dec 23, 2006 | 08:13 AM
  #924
Tippyman's Avatar
Default Re: (1990si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si &raquo;</TD></TR><TR><TD CLASS="quote">at least get the nitrous seup going. dont quit and start another project.</TD></TR></TABLE>
Oh, definately. I'll be running it all next year until the new one is setup.
Old Dec 23, 2006 | 08:16 AM
  #925
teamlegacy's Avatar
I've got some OBD1 Precision 580's that I was gonna use for my Nissan if you can find a way to use them.
