My 88 std hatch
Old Oct 12, 2009 | 09:02 PM
  #376
DCRB's Avatar
Default Re: My 88 std hatch
WHEW!! well today i spent a good eight hours swapping out my 4spd and installing my si tranny. a good hour and a half was spend ****ing driving around looking for a stupid clutch alignment tool. apparently no one sells a 20 spline tool, just the 21
while i was at it i also installed the prothane shifter bushings and motor mounts i got from apekd. going for a test drive now
Old Oct 12, 2009 | 10:02 PM
  #377
apekd's Avatar
They are FAWKING crazy man! Those mounts are SUPER hard. If I kept the civic I would have NEVER gotten them cause of how hard to are. Makes the car shake like a B16 with solid aluminum mounts. Go get some syncromesh, swap the pressure plates, and see if that noise is still there and if it grinds a bit in high RPMS in 3rd.
Old Oct 12, 2009 | 11:47 PM
  #378
DCRB's Avatar
man my car pulls! vibrates like hell cuz of the motor mounts, but i kind of like it. just gotta turn up the beats a little bit. making a weird noise tho. starts when i shift into second and lasts through fifth after sitting, and then makes it again once going. i fixed an exhaust leak (sort of) and my exhaust sounds nice and deep, no more raspyness... weird.
here's the vid of what's wrong with my car. the noise you here is NOT my exhaust. it is the weird pop can rubbing on a tire noise. my exhaust is a deep tone.
always gotta be something i guess.
on a side note swapping headgaskets COMPLETELY eliminated all smoke from my exhaust, as far as i can tell. then again, i've only driven it at night
Old Oct 13, 2009 | 02:08 AM
  #379
DCRB's Avatar
mmmmmmmmmm just did a bunch of "research" on brake upgrades. found out that a certain acura vehicle came from the factory with twin piston calipers, and i also learned what i need to properly install 10.3" rear discs on my hubs from the factory.
so in other words, i now know exactly what i need to buy and modify to perform a full big brake upgrade front and rear on my car. not sure when it will happen, but eventually i will be rocking 11.1" front brakes, and 10.3" rear brakes with an itr 1" mc and brake booster combo. my ****'s going to stop literally on a dime
Old Oct 13, 2009 | 06:37 AM
  #380
garageEF's Avatar
For future reference, a long half inch drive extension wrapped with the right amount of masking tape makes a great diy clutch alignment tool.
Old Oct 14, 2009 | 01:55 AM
  #381
DCRB's Avatar
mmmmmmmm just got done helping my buddy steven with his 91 std. his 88 dx tranny blew up, so we got our hands on a 91 dx with a clutch, and tossed that bad boy in. one refurbished axle later and bam his car is back up and running again. i think something might be wrong with my car tho... cuz his pulls just as hard as mine... yet mines supposed to be lighter...
his specs:
d15b1 dpfi with the restrictor thingy removed
ebay intake
si cam
dx trans with stock clutch
stock 4-1 header with 3" cat back to a subie HUGE *** can (sounds good tho)
silicone filled stock motor mounts
ebay short shifter
stock head gasket
my specs:
d15b1 mpfi swapped - z6 intake mani w ls tb and pm6 ecu
si cam
si trans (i know it is infact an si trans)
stock clutch and pp
custom intake to stock air box with paper filter
z6 4-2-1 header to 2.5" test pipe to 2.25" sir cat back
ignition timing not set...
stock gsr shifter
y8 head gasket
just thought it was weird. if the mpfi REALLY doesnt make a difference then i'm almost tempted to see what happens if i go back to dpfi. lol
Old Oct 14, 2009 | 08:27 PM
  #382
apekd's Avatar
hehe ill let you update the thread homie. glad i could help with it today. Ill start to price out bearings if you want.
Old Oct 14, 2009 | 10:15 PM
  #383
DCRB's Avatar
me and my buddy steven last night rolling around
new header:
today, with the help of apekd, i replaced my pilot bearing, pressure plate and installed an ebay 4-2-1 header. made my car sound a bit raspy, but then again, that could be because my exhaust doesn't fit propperly and it's stretched to fit. aka when just hanging there's about a 1" gap between my test pipe and my header. oh well, when i get a car installed i'll have the exhaust shop fix that ish. going to get my ignition timing set tomorrow. right now my car bogs from idle to about 2500 rpms then just TAKES OFF. it sucks cuz i either rev it too high and then end up spinning my tires or i have to VERY gently slip the clutch. which doesn't work so well when having to go from a stop while going up hill. also i'm going to be swapping to an electronic vss for sure tomorrow, too much of a hassle with the ghetto **** i made up with my cable vss to make my teg cluster's speedo work properly. plus i think i broke my speedo cable today.
Old Oct 15, 2009 | 05:07 PM
  #384
DCRB's Avatar
mmmmmmmmm smashed around a little bit in it today. either i'm getting used to the noise it makes, or the noise is going away... but ***** fast!!! lol i can't wait for my high compression a6 to be done tho.
Old Oct 17, 2009 | 12:03 AM
  #385
DCRB's Avatar
ugh well i think i'm going to mini me/convert to obd1 tomorrow. thing is still not running correctly, runs rich and bogs a bit in well any gear untill about 2500-3000 rpms depending on what gear it is in. idk maybe i'm just missing something, but my buddy's car seems to work and not run rich just fine and he's still dpfi. so grrrrrrrrrrrrrr
Old Oct 17, 2009 | 02:27 AM
  #386
DCRB's Avatar
guess i can post this now as ever.
swapped decks between my civic and my van. van now has the 4+ year old alpine, which makes the van sound better. civic has the nice new kenwood that never worked right in the van. sounds GOOD. plus i have like every feature available on the kenwood.
then got pissed at the car cuz it still isn't throwing any codes, and still is running rich and getting like 19mpg, and is still bogging until like 2500 rpms. tried swapping ecus with another pm6 and ps9 i have laying around, didn't notice a difference in either boggyness or fuel consumption (exhaust still stinks like gas). also got mad because i WISH i could tear it all down this winter and build it right, but because there's the possibility of a 30 day notice chillin over my fam's heads i don't want to start any more projects until we have a guaranteed place to stay. damn landlord going into foreclosure.
*sigh* going to see if it runs any better if i convert it to obd1 and mini me it tomorrow
Old Oct 17, 2009 | 07:55 AM
  #387
EK-ek's Avatar
my buddies car bogged too and we got a new dizzy and it was fixed maybe its your dizzy? and for your bad gas mileage check your o2 sensor maybe you need a new one and also if you have a catalytic converter you might have to replace that.
Old Oct 17, 2009 | 09:21 AM
  #388
DCRB's Avatar
huh dizzy eh? that could deff. be an issue, the one i have is used... but newer... my o2 sensor has a whopping 400 miles on it, and i don't have a cat, so i think i can rule those two things out... that's why it's so weird
Old Oct 17, 2009 | 09:53 AM
  #389
my95dc2's Avatar
started getting better with the optional/ oem upgrades towards the middle, then the subs and amps ruined the trunk, to each there own but the car would be worlds faster without all that crap in there. just my opinion, otherwise youve come along way. congrats
Old Oct 17, 2009 | 04:44 PM
  #390
DCRB's Avatar
i took out my subs and it was faster. i just like beats. i'm working on a box for one sub. the speaker amp stays regardless, because the speakers sound like *** w/o them.
Old Oct 17, 2009 | 04:45 PM
  #391
DCRB's Avatar
i'm about to start my obd1 conversion, just gotta let the car cool down a bit then will be ready to go
Old Oct 18, 2009 | 11:37 AM
  #392
apekd's Avatar
shut up. just shut up. Yeah he has come a long way since I owned it, but everything he has done to it, I gave the thumbs up on it. so leave it be got it?
You where right bro, people are being newbs and hitting the BT with mean things. Maybe it they should have to PM you with what they are gonne say before it can get posted? lol
Old Oct 18, 2009 | 11:54 AM
  #393
my95dc2's Avatar
so im not aloud to complement your friend on his progress? He had a sub box bigger than some tool boxes and I was just making a statement seeing as after I read his entire build thread and gave him credit for it he seemed like he was craving for more power. with such a small powerplant with essentially just bolt ons the easiest thing I saw was removing the woofers to get a little quicker. And who are you that as long as you "give him the thumbs up on" it makes it correct? DCRB, your doing a good job. A paint job and your going to look good. tell your friend to calm down
Old Oct 18, 2009 | 02:32 PM
  #394
DCRB's Avatar
now now apekd, relax. every one IS entitled to their opinions, even if i do bitch about said opinions to my pillow late at night. lol
yeah i know my subs weigh as much as a small dirt bike, it was the only box i had tho. someday i'm going to have a custom box made out of the spare tire well, which will give me the trunk space i want with the beats i want, but with out making as much weight. my95dc2, thank you for your comments and props, and yes, thank you for disliking things on my car as well. it helps me make my car that much better
Old Oct 18, 2009 | 08:39 PM
  #395
apekd's Avatar
^I dont take nicely to people bein rude to a homie. specially a homie that I happen to live with.
Ryan, there is a box plan for 1/2" mdf for a spare tire box. but they are easy to make. Ask Beans about it. he can probably design it too
Old Oct 18, 2009 | 08:40 PM
  #396
apekd's Avatar
lolz just saw your at the "neverland ranch"............hehe wow......
Old Oct 18, 2009 | 09:51 PM
  #397
DCRB's Avatar
hahahahaha just read your siggy. here's how that played out...
i live across the street from a church. around noon i start cleaning my car, and had kgon on and they were playing some zz top. so of course i'm blasting it. any ways my mom comes out and yells at me to turn it down so i do not upset the church folk.
i'm like what, they just got filled up on god, time to rub a little Satan on them.
apekd then starts BUSTING up laughing. lol
in other news i drove it around today a bit, then tonight i took my bra off for the winter. i don't want it getting any more messed up than it currently is.
perhaps this winter i'll work on my sewing skills and make my own bra?
Old Oct 19, 2009 | 12:13 AM
  #398
apekd's Avatar
How about we take time this winter to get the A6 built and thrown in? lol of course ill be here to help and get goodies from my ford buddies who love to help me out too
Old Oct 21, 2009 | 05:03 PM
  #399
DCRB's Avatar
blah drove it around last night, burned hella gas, bottomed out a couple times on dips in the road that jumped out of no where. going to go mess with timing right now, if i can get it right perhaps it will run correctly. new job!!! yay me!! going to go mess with my timing now
Old Oct 22, 2009 | 11:06 PM
  #400
apekd's Avatar
YAY for job....YAY for a homie that pays me back...lol ill bring the test pipe and GSR calipers for ya tomorrow after my interview....lets say 30$ for it all total.....hehe glad your getting my HALO 3 for me too....come to my party next month man. Come on! itll be fun!
