Torque Specifications for ARP headstuds in ls/vtec
What are the torque specifications when using gsr ARP headstuds in an ls/vtec with the molylube or regular oil? Thanx-Paul
Re: Torque Specifications for ARP headstuds in ls/vtec (tnsxsear1)
any1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnsxsear1 »</TD></TR><TR><TD CLASS="quote">What are the torque specifications when using gsr ARP headstuds in an ls/vtec with the molylube or regular oil? Thanx-Paul</TD></TR></TABLE> with the moly lube NO more than 70lbs... regular oil i belive it's 66ish https://honda-tech.com/forums/images...s/emsmilep.gif
Re: Torque Specifications for ARP headstuds in ls/vtec (DEVIOUS_EF*)
do 26 ft lbs the first pass 63 second pass and 75 third. w/ assembly lube
32ft.lbs 1st. 2nd is 65ft.lbs.
Re: Torque Specifications for ARP headstuds in ls/vtec (10000rpm)
Which torque specs are correct? Everyone's response is different.
Re: Torque Specifications for ARP headstuds in ls/vtec (85mm LS VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* »</TD></TR><TR><TD CLASS="quote"> with the moly lube NO more than 70lbs... </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif
you have to use a 2 step sequence. I say u do the first opne at 26 and the second and final at 70. I just did mine yesterday https://honda-tech.com/forums/images/smilies/emthup.gif .
Re: Torque Specifications for ARP headstuds in ls/vtec (Boost2NA)
the instruction sheet sais to disregard the stock specs,and to give the final torque of 75
foot lbs,but with aluminum application,end it with 65 ft lbs so final answer---65 ft lbs with the lub---- |
Re: Torque Specifications for ARP headstuds in ls/vtec (LaminaRX)
:edited:
Modified by Jeterkm02 at 10:39 AM 10/4/2006 |
