Torque Specifications for ARP headstuds in ls/vtec
Old 04-30-2004, 12:22 PM
tnsxsear1's Avatar
Default Torque Specifications for ARP headstuds in ls/vtec
What are the torque specifications when using gsr ARP headstuds in an ls/vtec with the molylube or regular oil? Thanx-Paul
Old 04-30-2004, 01:45 PM
tnsxsear1's Avatar
Default Re: Torque Specifications for ARP headstuds in ls/vtec (tnsxsear1)
any1?
Old 04-30-2004, 03:35 PM
DEVIOUS_EG*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnsxsear1 &raquo;</TD></TR><TR><TD CLASS="quote">What are the torque specifications when using gsr ARP headstuds in an ls/vtec with the molylube or regular oil? Thanx-Paul</TD></TR></TABLE> with the moly lube NO more than 70lbs... regular oil i belive it's 66ish
Old 04-30-2004, 04:03 PM
lsvtec101's Avatar
Default Re: Torque Specifications for ARP headstuds in ls/vtec (DEVIOUS_EF*)
do 26 ft lbs the first pass 63 second pass and 75 third. w/ assembly lube
Old 04-30-2004, 05:27 PM
10000rpm's Avatar
32ft.lbs 1st. 2nd is 65ft.lbs.
Old 04-30-2004, 08:48 PM
85mm LS VTEC's Avatar
Default Re: Torque Specifications for ARP headstuds in ls/vtec (10000rpm)
Which torque specs are correct? Everyone's response is different.
Old 04-30-2004, 08:57 PM
Default Re: Torque Specifications for ARP headstuds in ls/vtec (85mm LS VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* &raquo;</TD></TR><TR><TD CLASS="quote"> with the moly lube NO more than 70lbs... </TD></TR></TABLE>
Old 04-30-2004, 09:32 PM
Boost2NA's Avatar
you have to use a 2 step sequence. I say u do the first opne at 26 and the second and final at 70. I just did mine yesterday .
Old 04-30-2004, 10:31 PM
LaminaRX's Avatar
Default Re: Torque Specifications for ARP headstuds in ls/vtec (Boost2NA)
the instruction sheet sais to disregard the stock specs,and to give the final torque of 75
foot lbs,but with aluminum application,end it with 65 ft lbs
so final answer---65 ft lbs with the lub----
Old 10-03-2006, 11:17 AM
khmboostedeh2's Avatar
Default Re: Torque Specifications for ARP headstuds in ls/vtec (LaminaRX)
:edited:
Modified by Jeterkm02 at 10:39 AM 10/4/2006
iheartjayDem
10-03-2006 08:54 PM
b18_racer805
10-06-2005 05:00 AM
ptsaurus
20
06-06-2004 02:04 PM
lintegras
10
12-03-2003 08:54 AM
G-reX
10-06-2003 04:55 PM
Quick Reply: Torque Specifications for ARP headstuds in ls/vtec
