Suggestions Needed: b16 Cable Transmission OBD0 Vehicle Speed Sensor
i have a cable b16 obd0 tranny and the vss dont have a plug for the harness like the obd1 vss have. if i take a vss off a obd1 tranny would it work on my tranny ?
re: Suggestions Needed: b16 Cable Transmission OBD0 Vehicle Speed Sensor
It doesn't have plug cause it uses a cable for the vss, first off what kind of car do you have? Does your gauge cluster support a cable or electronic vss?
as stated above obd-0 uses a CABLE
as aposed to a obd-1 witch shares information via an electrical connector.
You need use cable then your gauge cluster in da is operated by the cable itself so as long as it's a cable vss you be fine
I have a cable transmission b16 with hydraulic conversion in a eg and I’m running into the same problem with mechanical speed sensor. I was wondering if I can swap it with an electrical speed sensor if I can from which transmission?
Yes, they are interchangeable. I'm running a speedo cable in a crv trans in my crx. My ecu reads my speed just fine. I'm running a electronic vss in my other crx in a cable trans because I used an ek engine harness for it since it's a drag car and doesn't have a chassis harness. The ecu reads speed on both cars.
Jedi Jake
05-12-2007 05:38 AM
