stock-looking fuel pressure regulator
Old 06-14-2006, 06:38 PM
( o )( o )'s Avatar
Default stock-looking fuel pressure regulator
With the latest trend of officer education on what doesn't belong under the hood of an import in California, how does one modify fuel pressure while not having a big *** anodized purple FPR on the fuel rail? The stock FPR is so small compared to a modified aftermarket version. Officers tend to notice shiny things under the hood...
Are there any adjustable FPRs out there that look stock? Are there any other options?
(I searched but all I found was classifieds...)
Old 06-14-2006, 09:24 PM
Eddiebx's Avatar
get one and paint it black, heh
Old 06-14-2006, 11:29 PM
shorto85's Avatar
I've been trying to figure out a solution to this as well.
Old 06-14-2006, 11:42 PM
JDM_COUPE's Avatar
Default Re: (shorto85)
get a silver b&m one. it looks stock
Old 09-14-2006, 09:20 PM
salman's Avatar
Default Re: stock-looking fuel pressure regulator (( o )( o ))
if u just wnat to increase the fuel pressure, just install a Inline fuel pump. after the stock,
It will add 30 psi to your stock Fuel pressure,
Old 09-14-2006, 09:23 PM
b19coupe's Avatar
I run the stock fpr and am making in the neighborhood of 240 whp-I am also running 440 cc injectors and a Hondata S300.
My engine bay would not pass a detailed CHP inspection though
Old 09-14-2006, 09:41 PM
DYNO-PRO
WHITFIELD-TUNED's Avatar
Location: SoCal I.E 909, CA, where we innovate not immitate
Default Re: stock-looking fuel pressure regulator (b19coupe)
I completely agree with todd.... The best way is to leave stock regulator and tune your car in something such as crome-pro or hondata no fpr needed ... But 4 those out there that must have an adjustable fpr.... You can leave the stock one one the rail and install a remote mount adjustable one dowstream from the stock one (way down low or under intake manifold) but then again the fuel press guage gives it away
Old 09-14-2006, 10:35 PM
B18 CYA's Avatar
Default Re: stock-looking fuel pressure regulator (WHITFIELD-TUNED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHITFIELD-TUNED &raquo;</TD></TR><TR><TD CLASS="quote">I completely agree with todd.... The best way is to leave stock regulator and tune your car in something such as crome-pro or hondata no fpr needed ... But 4 those out there that must have an adjustable fpr.... You can leave the stock one one the rail and install a remote mount adjustable one dowstream from the stock one (way down low or under intake manifold) but then again the fuel press guage gives it away</TD></TR></TABLE>
or just move to canada, we dont have that kinda crap here
Old 09-15-2006, 03:17 AM
Chillinit's Avatar
Default Re: stock-looking fuel pressure regulator (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">
or just move to canada, we dont have that kinda crap here </TD></TR></TABLE>
Well, not where you live but cops are ******** down here.
As said before, a stock fuel pressure regulator is best. Stay away from those B&M units..they aren't consistant!
Old 09-15-2006, 04:30 AM
Furyof4's Avatar
Default Re: stock-looking fuel pressure regulator (Chillinit)
If you need a little more fuel pressure than the stock fpr, you can dent the top in. It will increase the pressure slightly. Ghetto...I know
Old 09-15-2006, 05:53 AM
type B16's Avatar
are civic and integra stock fpr the same? i mean do they all give the same pressure?
Old 09-15-2006, 10:09 AM
cjames235's Avatar
Default Re: (type B16)
yes all the same
Old 09-15-2006, 12:35 PM
thesmogman's Avatar
It took me an hour to search the CARB list and to my dis-belief there is not a CA legal AFPR or rail on the list for any Honda/Acura
It would be considered a modification of the fuel injection system and would fail the smogtest. (Visual)
The highest fuel pressure listed in the Motor book is for a Acura at 46psi on the 94-00 1.8liter, Also the 98-00 2.2liter
However there might be another manufacture's FPR that you could adapt to fit the rail. Might wanna check into this more.
Old 09-15-2006, 07:09 PM
RTFM
v4lu3s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">are civic and integra stock fpr the same? i mean do they all give the same pressure?</TD></TR></TABLE>
they are not all same actually. I know for a fact that 92-96 preldue vtec ones set pressur around 36-38 psi, while a 97-01 prelude on is up in the 47-54 psi range, same situation with the various ones on B series engines, i know for a fact that the gsr runs higher pressure than the ls.
Old 09-17-2006, 08:39 AM
cjames235's Avatar
Default Re: (v4lu3s)
hmmmmm good info!!
danmej1
11-05-2010 06:33 PM
Niskyspy
03-04-2006 03:30 PM
Bad-T
06-14-2005 09:57 AM
gsrboost
03-07-2005 12:24 PM
Quick Reply: stock-looking fuel pressure regulator
