pr4 pistons any good?
Old Sep 7, 2009 | 06:48 PM
_kiid's Avatar
Default pr4 pistons any good?
ok im changing my headgasket i have a b16 head with gsr block. soon to have gsr cams in it
when i took the head off the pistons says pr4 .8 is this any good for boost? its been boosted i just wanna see if its any good if not ill change it since the head is off
how much can it handle?
thanks!
Old Sep 7, 2009 | 06:57 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: pr4 pistons any good?
With the info given you should have around a 9.4:1 compression ratio which is boost friendly. It will not handle a crazy amount of boost since they are stock B18 A/B pistons. I would say a max of 12-15 lbs with a good tune assuming everything is in good shape. Remember a touch of detonation on stock cast pistons means an explosion that will make you frown.
Old Sep 7, 2009 | 07:04 PM
_kiid's Avatar
oh alright thanks
im thinking about getting a thicker headgasket to is that fine?
Old Sep 7, 2009 | 07:07 PM
DO IT ON ALL FOURS
No, don't do it there is no point unless you want an extrmely doggy motor. Just stick with the standard .030" and all will be good. (Not only that but it ruins quench...) Either that or just do what you want...
Old Sep 7, 2009 | 07:09 PM
_kiid's Avatar
oh ok thanks
good thing i didnt order it yet thanks
Old Sep 7, 2009 | 07:17 PM
_kiid's Avatar
do i jst order one for a gsr or b16? or it has to be made for my setup? or there all the same?
Old Sep 7, 2009 | 07:28 PM
DO IT ON ALL FOURS
Either one will work it does not matter. Just make sure it is for a VTEC and you will be all good...
NotAJDMFanBoy
Apr 14, 2012 10:49 PM
carlossolorzano
Nov 29, 2011 11:58 AM
94LS_allmota
Aug 6, 2009 10:41 AM
blundar
Apr 26, 2006 09:46 PM
