Suggestions Needed: SiR2 b16a with CTR cams, I/H/E - Mods before opening the engine?
Old 03-08-2018, 04:40 AM
94SiRswap's Avatar
Default Suggestions Needed: SiR2 b16a with CTR cams, I/H/E - Mods before opening the engine?
Okay so I have my ej1, it's been a fun ride,reliable etc. I put the CTR cams in, and tuned it. Made 156whp 110wtq on a ebay crap header and SRI,and a straight through 2 1/4in exhaust. So, now I have a 3in CAI, KN filter, RMF narrow rep header, and am going with a 3 in exhaust. I'll probably be straight through with the exhaust beside a 3in ultra quiet vibrant resonator,and my ktuned 3in turn down muffler.
That all being said, what else would be worth while doing before I go get retuned? The p30 intake manifold is basically unbeatable up to 8k, if I get a 66/68mm throttle body, I'll have to port match it.
I don't think it'd be worth doing anything to the TB or IM unless I found a fully ported p30 matched to a 66mm or so tb. Or should I go performer X with a 66mm?
^^ that's pretty much all there is left to do before I crack the motor open, right?
Old 03-08-2018, 09:41 AM
Chance EG's Avatar
Default Re: Suggestions Needed: SiR2 b16a with CTR cams, I/H/E - Mods before opening the engi
If you can afford it the Performer X would likely yield some mid range gains (definitely top end) especially in conjunction with the header you've chosen. Those RMF headers seem to be built for high RPM useage (they're a 4-1 design correct?) Kinda sounds like you're trying to get some mid range out of this for a fun daily, it may have been a bit better to get a 4-2-1 header.
I would consider the Performer X and a 66->68mm throttle to be a worthwhile upgrade for your engine. It would compliment the larger intake tube you have as well.
What are you planning to do after opening the engine? With the bolt ons you've selected, and the mid-range power you seem to be aiming for, I don't really know if there's many gains to be had for you switching out pistons or anything like that at this point, unless you're just reinforcing the engine.
Old 03-08-2018, 11:37 AM
94SiRswap's Avatar
I have another car that's more of a project, so I am going to be focusing on that, and sort've backburning the civic after said mods are done.
I mean if I do open it up,and stay all motor; ill prolly go high 11 or 12.1 comp nippon pistons,arp head studs,b20 block,arp rod bolts,accompanied with my b16 head ---- I have a b20 bottom end just sitting around. But that's very far in the future,and realistically I'm going to end up boosting it anyway.
So the performer X would be worth it over the p30 now? I don't have a lot of dough to throw at this car, I feel the gains would be miniscule? Also disregard my saying I'm going boost in the future,I want to buy parts (if theres any worthy bolt ons left lol) and retune,and be done with this car for the next season or two.
Tia dudes.
Old 03-08-2018, 02:50 PM
Stopsign32v's Avatar
4” short ram intake with a large filter
Performer intake with a TB that matches the opening of the intake
should make a noticeable difference with the better exhaust.
vbspec
08-11-2004 07:09 PM
EF-Si-R
11-20-2003 09:52 AM
TwistedSI
10
04-14-2003 08:29 AM
dohcvtecsol
07-11-2002 07:10 AM
91sifreak
01-04-2002 05:14 AM
Quick Reply: Suggestions Needed: SiR2 b16a with CTR cams, I/H/E - Mods before opening the engine?
