Fields V-tec Controller on the Skits...
Old Feb 28, 2002 | 06:25 AM
joy-Ride's Avatar
Default Fields V-tec Controller on the Skits...
When I was auto crossing this weekend I usually stay in second gear w/the rpm's close to being in or out of the v-tec range ie; 5k-57k. When I stay in this range for long periods of time the built in rev limiter that came w/the controller seems to kick in and I cant shift past 55k ,and the only way to reset it is to turn the car off and then back on and when racing this can be very annoying; so annoying I turned the dam thing off. I enquired about this very same thing about a 6months ago; and somebody advised to cut the DTM wire and double check the dip switches in the back all have been done and still same problem. Is my controller a defect maybe or does anybody else experience this same problem, or would a Apexi controller be better....please help
Old Feb 28, 2002 | 07:40 AM
sgT's Avatar
sgT
Default Re: Fields V-tec Controller on the Skits... (joy-Ride)
Sounds like the VTM wire isnt hooked up
Old Feb 28, 2002 | 07:48 AM
joy-Ride's Avatar
Default Re: Fields V-tec Controller on the Skits... (sgT)
thats the wire i cut not DTM;its early...Somebody on H-T told me to disconnect that wire and that it wasnt needed,also he provided me w/instruction off of the inet for the controller and it also stated for itr's to cut the VTM wire....
Old Feb 28, 2002 | 07:52 AM
sgT's Avatar
sgT
you have to cut it and connect it to the field controller.
Make sure you connect the ecu side to the controller
812mja
Sep 2, 2013 05:26 AM
93vtec
Mar 3, 2004 01:50 AM
crxsi26
Dec 26, 2003 04:17 PM
YEE*MagicEK20kombobomber
Feb 25, 2003 08:12 PM
