how to properly hook up a vtec controller?
Old Aug 26, 2013 | 06:36 PM
812mja's Avatar
Icon2 how to properly hook up a vtec controller?
i have a obd2a ecu and i have power,ground, illumination, ran correctly because it turns on and off with the key. when i went to hook up the rpm wire. i got a reading but it was jumping all over the place. the tack on the dash was working but the digital reading on the controller wouldnt read right. where is the right wire to splice into?
Old Aug 26, 2013 | 06:45 PM
doood's Avatar
been there done that
Default Re: how to properly hook up a vtec controller?
the trash can
seriously, it's 2013 why are you using a vtec controller?
Old Aug 26, 2013 | 07:01 PM
812mja's Avatar
because i have it. and remaping a ecu or anything like that is out of my league. and i dont have the money or time to send it off and have it done. im happy with the tune for now. all i would like to do is change where the vtec hits.
Old Aug 26, 2013 | 07:04 PM
NZXTInerTia's Avatar
Well first you pull out your soldering iron, then you put your soldering iron back and throw your VTEC controller in the trash.
Old Aug 26, 2013 | 07:07 PM
doood's Avatar
you realize that does absolutely nothing for you when you cant change corresponding fuel and ignition values, right?
Old Aug 26, 2013 | 07:09 PM
812mja's Avatar
no didnt know all that. so does anyone know what wire to tap into for the rpm signal
Old Aug 26, 2013 | 07:14 PM
812mja's Avatar
regardless since i already have it i would like the digital rpm display and shift light.
Old Aug 27, 2013 | 08:33 AM
812mja's Avatar
So nobody can tell me what wire is the correct rpm wire to tap into?
Old Sep 2, 2013 | 05:26 AM
No one will help you because garbage.
/thread
96_civic_dx_b16
Engine Management and Tuning
Nov 9, 2010 04:11 PM
ExCiViChYbRiD
Oct 20, 2007 07:14 AM
crxsi26
Dec 26, 2003 04:17 PM
[626] SiRJKwIcK89Ef
27
Oct 10, 2001 03:33 PM
[626] SiRJKwIcK89Ef
Oct 10, 2001 06:37 AM
