Driver Side Window
Old Jan 16, 2003 | 11:36 PM
Phoenix Yellow R's Avatar
Default Driver Side Window
My driver side window is making some weird sqeaking noise and it goes down REALLY slow, 2 of my friends have the same problem, and they said its normal for Integra??? So, I am just wondering if anyone here has the same problem???
Old Jan 16, 2003 | 11:37 PM
SoCal ITR's Avatar
Default Re: Driver Side Window (Phoenix Yellow R)
I think it just needs some silicone... Yoshi234 knows.
Old Jan 17, 2003 | 01:49 AM
CWESTINAP1's Avatar
Default Re: Driver Side Window (SoCal ITR)
i've had that problem also, but it goes away when u wash your car. im pretty sure about that.
Old Jan 17, 2003 | 01:55 AM
ILLTEGRA
Guest
Posts: n/a
Default Re: Driver Side Window (CWESTINDC2)
my driver side window is loose and rattles when i open the window half way, anyone else experience this too?
Old Jan 17, 2003 | 03:11 AM
typer.org's Avatar
take off the door panel and check it out. I had the same problem, but then it got worse. The rubber inside the slot where the window goes up and down came out so I had to put it back in. I could tell if the window was down slightly and when I closed the door you could hear the glass hitting metal.
Old Jan 17, 2003 | 04:26 AM
Mugen Mike's Avatar
Look here:
https://honda-tech.com/zerothread?id=322644&page=1
Old Jan 17, 2003 | 05:19 AM
RTW DC2R's Avatar
Default Re: Driver Side Window (MugenMike)
I would take off the door panel, tighten everything up, check the slots the window travels in, and use some l00b and it will be like buttah. it not really that hard to do, maybe take 30min or so. watch out for the gooey stuff holding the protective plastic sheet inside the door panel, that **** gets all over everything
Old Jan 17, 2003 | 05:24 AM
Eva01's Avatar
Default Re: Driver Side Window (RTW DC2)
Here an article to fix the window rattle: http://www.team-integra.net/sections...?ArticleID=552
deerman2701
Nov 27, 2007 05:59 AM
OriginalFive
Honda S2000
May 3, 2006 10:11 AM
type Gendy
May 18, 2004 07:37 PM
gsrhunny
Oct 2, 2002 11:23 AM
rsx03
Nov 15, 2001 10:17 PM
