small rattle from driver's window when partially opened
Old Nov 14, 2001 | 06:58 PM
rsx03's Avatar
Default small rattle from driver's window when partially opened
Has anyone ever had this on their teg?
It appears when you partially open your window.
Everytime you go over a small bump or uneven surface you can hear it rattle..
And it seems like it comes from the PIN GIUDE SYSTEM on the window.
I noticed even when the window is partial opened and i just bang at it from the outside of the glass, it gives out that rattle again..
ANYONE care to tell me what it is or how-to fix it??
Old Nov 14, 2001 | 07:00 PM
SamuraiJack's Avatar
Default Re: small rattle from driver's window when partially opened (2K1GSRBOY)
got the same problem.. have not idea how to fix it.
i would like to know also
Old Nov 14, 2001 | 07:10 PM
Duck Sauce's Avatar
Default Re: small rattle from driver's window when partially opened (SamuraiJack)
I also have that problem. Take it to the dealership
Old Nov 15, 2001 | 03:43 PM
project_DC2's Avatar
Default Re: small rattle from driver's window when partially opened (CWestIntegra)
I have the same prob. too?? I dont have warrenty anymore so why go to the dealer? They charged an arm and an leg to have that fix!!!!!!!!!!!!!!
Old Nov 15, 2001 | 03:50 PM
ACURACY_VTEC's Avatar
New User
Default Re: small rattle from driver's window when partially opened (project_GSR)
i have the same problem with both windows. does anyone have a fix?
Old Nov 15, 2001 | 03:59 PM
gsrapper's Avatar
New User
Default Re: small rattle from driver's window when partially opened (sweet-teg)
yeah me too and mine is a 99
Old Nov 15, 2001 | 05:08 PM
vti-R's Avatar
Default Re: small rattle from driver's window when partially opened (gsrapper)
i think someone said that this is a problem on g3 integras...
Old Nov 15, 2001 | 05:17 PM
Type Goch's Avatar
New User
Default Re: small rattle from driver's window when partially opened (vti-R)
same here, i think anything door related on integras suck ***! my doors rattle and the stick all this crap..
Old Nov 15, 2001 | 06:10 PM
FrostyGSR's Avatar
New User
Default Re: small rattle from driver's window when partially opened (Type Goch)
If you take off the door panel to expose the window there will be a cople of screws that are responsible for keeping the window tight on the track. I think that over time the screws become loose and you have to tighten them back up.......
Old Nov 15, 2001 | 06:28 PM
OneThirtyEight's Avatar
Default Re: small rattle from driver's window when partially opened (FrostyGSR)
Im not impressed with the quality of the Integras body and interior parts, they all seem real thin and cheap. Engine and suspension quality is great though
Old Nov 15, 2001 | 07:29 PM
TurBoTeG's Avatar
Default Re: small rattle from driver's window when partially opened (97blackteg)
I have the wobble to and ive investigated the problem...i think its a designer flaw..i just keep my windows all the way up or down so they dont wobble
Old Nov 15, 2001 | 09:11 PM
Anthony K's Avatar
New User
Default Re: small rattle from driver's window when partially opened (TurBoTeG)
My driver's side does the same. Mainly after I had it replaced though. I think it is an inherent problem with Integras. Try not to worry about it.
Old Nov 15, 2001 | 09:34 PM
Calavera's Avatar
Default Re: small rattle from driver's window when partially opened (Anthony K)
My driver side door does vibrate sometimes when the bass from the speakers are loud. I have stock stereo and speakers..so
Someone said once that when you take off the door pannel, there is a black rubber thingy that's supposed to be guiding the window as it comes down. The rattle stopped once they tightened the rubber guide.
I just remember reading it somewhere in this forum.
Old Nov 15, 2001 | 10:17 PM
nugget8000's Avatar
New User
Default Re: small rattle from driver's window when partially opened (Calavera)
As far as the window rattle goes-If you take off the inner door panel and peel back the plastic that seals off the door, you will find a rubber strip laying in the bottom of the door. Simply glue it back into place on the rear window track and you will be set. This is how I fixed this problem and as I heard this trick from other board members, other people have had the same luck.
While I am at it I may as well also note on the problem that our cars seem to have with the glove box not shutting all the way, and the light inside turning on sporadically, or even all the time. For this just take a small phillips head screwdriver and tighten down the latch/handle thing from inside the glove box. This worked for me. HTH.
KooK
May 4, 2006 03:13 PM
OriginalFive
Honda S2000
May 3, 2006 10:11 AM
seer_claw
Jan 31, 2004 01:53 PM
Yellb16crxsi
Mar 5, 2003 04:39 PM
Phoenix Yellow R
Jan 17, 2003 05:24 AM
