Honda S2000 Honda S2000
Power window problem
Old Apr 29, 2006 | 02:21 PM
OriginalFive's Avatar
Default Power window problem
My driver door window is starting to have a problem. When i roll down the window all the way, half way through it starts to shake pretty hard. It seems like its catching something on its way down. Im not sure if any of you members had this problem and would know what it is. I wont be able to check the problem until i get home.
thanks for viewing!!
Old Apr 29, 2006 | 05:52 PM
specbb6's Avatar
Default Re: Power window problem (OriginalFive)
kind of weird problem. Hopefully your window relay isnt bad.
My advise; try taking the door panel off, and see what is obstructing the window from normal operation.
Old May 1, 2006 | 11:43 AM
gfhb4s2000's Avatar
Default Re: Power window problem (specbb6)
sounds like you have a window regulator going bad i am a tech at richmond bmw and we are always having to replace window regulators and if the design is anything like our on a cable and pulley set it sucks. Take the door panel off and check it out see if anything is in the way also you could try to spray some white litheum grease on the track its self just be carefull not to get it on your window its really hard to get off.
Old May 1, 2006 | 12:45 PM
LBBP R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specbb6 &raquo;</TD></TR><TR><TD CLASS="quote">kind of weird problem. Hopefully your window relay isnt bad.
My advise; try taking the door panel off, and see what is obstructing the window from normal operation.</TD></TR></TABLE>
yup, take the panel off and take a look at the window..
Old May 1, 2006 | 05:55 PM
Wirelesseffect's Avatar
Default Re: Power window problem (LBBP R)
thanks for the replies! i checked it and it seemed to be fine when i took the door panel off...weird, i guess it only happened on that day. but ill keep an eye on it, like you guys said..maybe its the window relay is starting to go bad.
Old May 2, 2006 | 06:05 PM
gfhb4s2000's Avatar
Default Re: Power window problem (Wirelesseffect)
sometimes when the seals around the window dry out they can cause to window to shake going down and make some noise.
Old May 3, 2006 | 10:11 AM
S CARTER's Avatar
Its a pretty strange problem but i have heard of it before its a service bulletin 01-008
SYMPTOM
When the top is lowered or raised, or the driver tries to
use the AUTO down function for the power window, the
window goes down only 3 or 4 inches. The window
goes down all the way if you push and hold the power
window switch.
PROBABLE CAUSE
Contamination in the window motor causes a loss of
electrical ground.
CORRECTIVE ACTION
Replace the window regulator assembly.
PARTS INFORMATION
Left Window Regulator Assembly:
P/N 72250-S2A-A03, H/C 7398753
Modified by S CARTER at 2:47 PM 5/3/2006
4Dinsaneb16
Mar 20, 2007 01:30 PM
C2daIzZle
16
Sep 9, 2005 05:06 AM
Yellb16crxsi
Mar 5, 2003 04:39 PM
Phoenix Yellow R
Jan 17, 2003 05:24 AM
