Conversion Progress :)
Old Mar 15, 2006 | 11:36 AM
  #126
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">did u dump the supra and jumped on the K series bandwagon??
good move if u dumped the supra
never the less car is looking mighty goood..</TD></TR></TABLE>
When did George ever have a Supra?
And George, Todd Reid had a problem with the reverse lockout thing as well, and it was ECU related. Shoot him a PM
Old Mar 15, 2006 | 04:29 PM
  #127
Modest Mouse's Avatar
Default Re: (sscguy)
Wow, Gorgeous R Grandpa
Old Mar 15, 2006 | 10:00 PM
  #128
SEFIxCivic's Avatar
i got a coupke friends who track their k20 eg's and so far they have yet to crack their oil pans at the track. i do know one person who did have a mishap driving around the streets of San Francisco though.
Old Mar 15, 2006 | 10:02 PM
  #129
JjuuN R's Avatar
Default Re: (SEFIxCivic)
heh, well streeting a K20 swap in San Fran is just asking to get that oil pan ripped off
Old Mar 16, 2006 | 06:40 AM
  #130
George Knighton's Avatar
H-T Order of Merit
Default Re: (JUN.R)
OK. It looks like there's hope for fifth gear.
The electronic reverse lockout is not working because of an incompatibility between the programme and the particular chip used for the programme.
This means that instead of being able to rely on being able to push over to the right all the way and then up, selecting fifth reliably, the shifter will go beyond the gate every time, making selection difficult.
All we have to do is rig up a manual switch that has reverse locked out all the time, until I need reverse.
Old Mar 16, 2006 | 12:36 PM
  #131
H-T Order of Merit
Default Re: (George Knighton)
Looks like it worked!
Old Mar 16, 2006 | 12:38 PM
  #132
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Looks like it worked!</TD></TR></TABLE>
excellent, if there was only a way to swap a k series in the s2k
Old Mar 16, 2006 | 12:43 PM
  #133
Default Re: (Evil Chubzilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Chubzilla &raquo;</TD></TR><TR><TD CLASS="quote">excellent, if there was only a way to swap a k series in the s2k</TD></TR></TABLE>
lol!
Old Mar 16, 2006 | 01:36 PM
  #134
cltitus's Avatar
How did you fix the reverse lock so when i get done swaping i wont have suck a hard time.
Old Mar 16, 2006 | 01:39 PM
  #135
chad's Avatar
Moderator
there is ..... but why would you want too???
Old Mar 16, 2006 | 01:40 PM
  #136
Chubz's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
there is ..... but why would you want too???</TD></TR></TABLE>
better moddibility
nothing better than dropping 3k on mods and getting 5whp on the s2k
Old Mar 16, 2006 | 01:43 PM
  #137
H-T Order of Merit
nothing better than dropping 3k on mods and getting 5whp on the s2k</TD></TR></TABLE>
Yeah. You might as well drive a Type R.
Old Mar 16, 2006 | 01:45 PM
  #138
Chubz's Avatar
Yeah. You might as well drive a Type R.</TD></TR></TABLE>
close had a 2001 GSR with a built b18c-r with JUN IIIs tuned by SGT
Old Mar 16, 2006 | 01:46 PM
  #139
H-T Order of Merit
JUN III + SGT &gt; ITR
Old Mar 16, 2006 | 01:48 PM
  #140
Chubz's Avatar
217whp and 136 tq not bad. I miss this board, the s2k forum is lacking
Old Mar 16, 2006 | 01:52 PM
  #141
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Chubzilla &raquo;</TD></TR><TR><TD CLASS="quote"> I miss this board, the s2k forum is lacking</TD></TR></TABLE>
Well, it's obviously kind of lacking over here, too. Otherwise, we wouldn't have the time to go off on these kinds of tangents.
Old Mar 16, 2006 | 01:53 PM
  #142
Chubz's Avatar
Well, it's obviously kind of lacking over here, too. Otherwise, we wouldn't have the time to go off on these kinds of tangents.</TD></TR></TABLE>
lmao
Old Mar 16, 2006 | 01:54 PM
  #143
H-T Order of Merit
Default Re: (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">How did you fix the reverse lock so when i get done swaping i wont have suck a hard time.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">
James, the reverse lockout works fine only if you use a 6 speed ECU. If hondata used a 5 speed (EP3 and like) and sent it, well, because its a 5 speed, it doesn't need to lockout reverse because there isn't a 6th gear to accidentally shift into. The "lockout" isn't even in the 5 speed ECUs.
So, basically where the shift linkage rods are at the transmission, there is a solenoid that if turned "on" (feed w/ 12 volts) it keeps someone from shifting into reverse. It needs to be hard wired with a switch. Take one wire from the solenoid and ground it, take the other, attach it to a switch, and get a hot lead from the battery with a fuse. Now the driver just turns the switch on during normal driving, and has to turn it off to go into reverse.
Hope this helps in the future.
Corey</TD></TR></TABLE>
Old Mar 16, 2006 | 01:58 PM
  #144
cltitus's Avatar
thanks got any pictures to help me out or a link to show exactly how?
Old Mar 16, 2006 | 05:01 PM
  #145
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: (Don Chubzilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Chubzilla &raquo;</TD></TR><TR><TD CLASS="quote">excellent, if there was only a way to swap a k series in the s2k</TD></TR></TABLE>
Worst post ever
Why don't you stick a K-motor in an NSX while you're at it? I'm sure your money goes further for modifications on that car too.
GK, glad to see it was a simple fix. I didn't want to have to pat you on the back after you money-shifted your K-swap, and say, "Don't you miss your B-series?"
Old Mar 16, 2006 | 05:03 PM
  #146
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">thanks got any pictures to help me out or a link to show exactly how?</TD></TR></TABLE>
This tells you exactly how to do it:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">So, basically where the shift linkage rods are at the transmission, there is a solenoid that if turned "on" (feed w/ 12 volts) it keeps someone from shifting into reverse. It needs to be hard wired with a switch. Take one wire from the solenoid and ground it, take the other, attach it to a switch, and get a hot lead from the battery with a fuse.</TD></TR></TABLE>
If you can't figure this out, I would recommend having a shop do it for you. This is a very simple, and straightforward procedure.
Old Mar 16, 2006 | 05:25 PM
  #147
Chubz's Avatar
Default Re: (Ross R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R &raquo;</TD></TR><TR><TD CLASS="quote">
Worst post ever
GK, glad to see it was a simple fix. I didn't want to have to pat you on the back after you money-shifted your K-swap, and say, "Don't you miss your B-series?" </TD></TR></TABLE>
good idea, ill try that
Old Mar 16, 2006 | 06:26 PM
  #148
bossman032's Avatar
I wouldn't mind an s2000 in a crx hf or something light.
heavy cars get K series motors
Old Mar 17, 2006 | 05:12 AM
  #149
Ross's Avatar
25 Year Member
Community Builder
heavy cars get K series motors </TD></TR></TABLE>
Well, George's car certainly qualifies if you're including the driver.
Old Mar 17, 2006 | 06:46 AM
  #150
Nikos's Avatar
To get an idea of how it could feel, here's a decent video of a civic EK k20a type r
http://www.k20a.org/h22avsk20a.wmv
